Ok,
i have spent countless hours trying to bleed the front brakes on my 1100F. I went out and bought a mityvac today from the local autoparts store and I spent 40 dollars on it. It hasn't helped at all.
Here is what I am doing.
First I bled the MC according to the instructions in the manual. (This was done because I am starting with an empty reservoir.)
I put a plug with a hose adaptor onto the outlet port, filled the reservoir, then kept pumping the might vac until I did not see any bubbles coming up from the reservoir.
I then connected the brake line to the MC outlet and proceeded to bleed the left caliper.
I connected a 3/16" hose to the bleeding screw, then connected it through an adapter to a larger house which fits the mityvac products. I pumped the mityvac until I got a good vacuum, then loosened the bleeding screw. I get a frothy mix of brake fluid. I then closed the bleeder screw and repeated the process.
I kept doing this and I could never get rid of the frothy mix. I am pretty sure it is because my connection at the bleeding screw is sucking in air when I create a vacuum. What can I do to seal this? I tried teflon tape, but it appears to dissolve in brake fluid.
I am really at my wits end.
Adam
Adam
If you bleed too slow, there is not enough flow past the bubbles to dislodge them and pull them through the system.
, I believe the pressure is the key to holding the lever, so your "squeezing" the air and encouraging it to move, Gravity will make it move up then. So I agree, the movement of the plunger does not open a passage, just adds pressure in the system.
Reminds me of my late brothers photograph caption: "Looking EAST as the sun sets" Which turned out to be a picture of Sunrise after a night of drinking Cider. His sense of direction was still good though his time of day was off.
