Once again
I posted this before, but I guess it went unnoticed. If you just take off the caliper and using large channel lock pliers, push the piston back as far as it will go while watching the resevoir fill up being carefull not to run it over, and all the bubbles that keep going up the line and refuse to come out the bottom will now go into the resevoir and your problems are over. Do both calipers this way and now all you have to do is pump the handle to push the caliper piston back to the point where the pads touch the disc, being careful not to run out of fluid in the resevoir. I did the vac thing first and had all the same problems you are having.
