Couldnt kill the bike and had to disconnect battery
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    Chewie, this may be your problem. If you bought RS catalog #275-1548, that switch is a normally-closed switch. You need a normally-open switch #275-1547. Looked it up on the shack's website.
    • Redshirt
      • Feb 2011
      • 142
      • Titusville, Fla.
      I posted a reply but apparently it didnt take.
      I got a 79 special and it has a black wire that runs to that screw from the wires entering the housing. The blue/white wire is also used.
      Davinci is right.
      I dont know if they color code the buttons, but Ive seen black buttons that are "off by default" and red ones that are "on by default" (or insert actual technical term).
      79 Special
      2012 FJR1300
      78 E (project. Clutch problems from PO) Must sell
      • DAVINCI
        • Jan 2011
        • 1048
        Actual 'technical terms' are
        Abbreviated NO - Normally open - at rest there is no continuity through the switch, the contacts are open. Push the button, contacts close.
        Abbreviated NC - Normally closed - at rest there is continuity through the switch. Push the button, contacts open.
        • chewie123
          • Mar 2010
          • 34
          • New York
          #34
          Yup - my switch is closed... I need to read the fine print better next time...Im going to radio shack in a bit to pick up the correct switch, then hopefully I can put this problem to bed. Thanks guys.
          • DAVINCI
            • Jan 2011
            • 1048
            #35
            glad that helped...did you get my PM?
