Some crazy s--t just happened.
I just started my bike for the first time after working on it all winter and I have definitely done something it doesnt like. I started it up after filling the carbs up and it screamed to full open and i turned the kill switch instantly. I figured I had the idle mix turned to far from bench syncing the carbs. i turned the screw, started the bike again and it screamed full open again and i hit the kill switch - nothing, turned the key - nothing, so I had to unscrew the battery to kill it. I really hope I didnt hurt the engine, it was full open for maybe 20 seconds, (I had to run back to get a screwdriver)...
Has this happened to anyone? Is it running wide open from the idle screw? I put it pretty damn close to what it was when i started. The butterflies are definitely closed when it was running open. But more important than that is why did it not turn off? When I turned the key, all the lights went off, I actually pulled the fuses to see if that would do anything and it didnt. I just put in a new battery today, I filled it, let it sit for a bit then charged it on 2 amp setting for about 3 hours.
I dont wanna try to start it again until i know what to address cause I really dont wanna burn up the engine like that again - been waiting a loooooooong winter to ride soon.
