So I've decided I'm going to not re-install that rediculously awkward airbox and go with pod filters to make service much easier. I was just wondering what brand y'all are running and how you like them? I have gathered that emgo sucks, mikes are good and most seem happy with them, and k&n are just overpriced. Anymore insight?
Which brand of pods
Tags: None
That seems to be the just of it.Nathan
Theodore Roosevelt -
Mikes XS pods are the best that I have seen or used. I have a set of K&N's that seem to want to fall off all the time. They now sit on the shelf ,Mikes's pods are the way to go.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
what about the breathers...
I see a small tube on top of transmission and a larger outlet at 90 degrees to it that seems to be crankcase ventilation.
Both would have hooked into airbox...without it what needs to be done? I have a small pod filter that can be adapted to the larger crankcase vent if I mount it remotely off a piece of the tubing since it is too close to the case to mount the mini-pod direct.
Should I tee these two together to the same filter? Do they need vacuum instead?
Sorry to hijack but figured you would need the same answers.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
You can buy a small crankcase breather filter for the larger hose. The smaller hose doesn't hook to the airbox, it's a vent for the middle drive unit which should remain open to atmosphere, doesn't need anything else.
The crankcase breathers are on this page, just before the pod filters...
http://www.mikesxs.net/products-40.html#productsLast edited by bikerphil; 03-19-2011, 01:55 PM.2H7 (79) owned since '89
☮Comment
Mikes is the way togo. I have the zrx1200r carbs and I left my 2 vent hoses way up under the gastank. Don't block them and yes. You can buy alittle breather if you like" She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairingComment
One of the Aussie xsers recently used a pair of twin carb pods and put a little nipple on the filter to run the crank breather to.Nathan
Theodore RooseveltComment
That smaller line is supposed to go up to a clamp up under the seat to keep it up away from water and such and allow it to vent without letting anything to getting sucked into the middle drive.Cy
I found your answers...
I had reposted my question on my thread because I didn't remember where I had asked
Guess I am getting older...
Thanks - i will route the hoses up to keep stuff out.
pods
APE Raceing, oval pods 59.00 set of 41979 xs1100 f
142 main, 45 pilot, Jardeen crosover 4/2, no air box
floats @ 25.7
1979 xs1100 F
1978 gl 1000 goldwing
1981 gl 1100 goldwing
!986 venture royale 1300
Just an ol long haired country boy, come to town to spend some egg money
when ya get bucked off, get back onComment
I had a set of Uni pods on the Mongrel and I really liked them. They were much better than the Parts N more ones that I think I still have in a box somewhere...
The old gray biker ain't what he used to be.Comment
