Which brand of pods
  • Stuckinmud15
    • Feb 2011
    • 64
    • Cheektowaga, NY
    Which brand of pods
    So I've decided I'm going to not re-install that rediculously awkward airbox and go with pod filters to make service much easier. I was just wondering what brand y'all are running and how you like them? I have gathered that emgo sucks, mikes are good and most seem happy with them, and k&n are just overpriced. Anymore insight?
    2007 Yamaha r6
    81SH
    That seems to be the just of it.
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      Mikes XS pods are the best that I have seen or used. I have a set of K&N's that seem to want to fall off all the time. They now sit on the shelf ,Mikes's pods are the way to go.
      BDF Special
      • jwhughes3
        • 2798
        • Home of the Alamo
        what about the breathers...
        I see a small tube on top of transmission and a larger outlet at 90 degrees to it that seems to be crankcase ventilation.
        Both would have hooked into airbox...without it what needs to be done? I have a small pod filter that can be adapted to the larger crankcase vent if I mount it remotely off a piece of the tubing since it is too close to the case to mount the mini-pod direct.
        Should I tee these two together to the same filter? Do they need vacuum instead?
        Sorry to hijack but figured you would need the same answers.
        John
        '81 XS1100H - "Enterprise"
          • 8962
          You can buy a small crankcase breather filter for the larger hose. The smaller hose doesn't hook to the airbox, it's a vent for the middle drive unit which should remain open to atmosphere, doesn't need anything else.
          The crankcase breathers are on this page, just before the pod filters...
          http://www.mikesxs.net/products-40.html#products
          • yamahansolo
            • Aug 2007
            • 1113
            • jawga
            Mikes is the way togo. I have the zrx1200r carbs and I left my 2 vent hoses way up under the gastank. Don't block them and yes. You can buy alittle breather if you like
            79 xs11 standard
            8mm msd wires
            tkat fork brace...
            Fox shocks...
            mikes650 front fender
            led's gallore...
            renthal bars
            gold valve emulators
            vmax tensioner
            Rifle fairing
              One of the Aussie xsers recently used a pair of twin carb pods and put a little nipple on the filter to run the crank breather to.
              • cywelchjr
                XS-XJ Super Guru(Deceased)
                • 4450
                • Sacramento, CA
                That smaller line is supposed to go up to a clamp up under the seat to keep it up away from water and such and allow it to vent without letting anything to getting sucked into the middle drive.
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  I found your answers...
                  I had reposted my question on my thread because I didn't remember where I had asked
                  Guess I am getting older...
                  Thanks - i will route the hoses up to keep stuff out.
                  John
                  • cowboybob998
                    • Mar 2009
                    • 371
                    • KC MO
                    pods
                    APE Raceing, oval pods 59.00 set of 4
                    1979 xs1100 f
                    142 main, 45 pilot, Jardeen crosover 4/2, no air box
                    floats @ 25.7
                    1979 xs1100 F
                    1978 gl 1000 goldwing
                    1981 gl 1100 goldwing
                    !986 venture royale 1300
                    Just an ol long haired country boy, come to town to spend some egg money
                    when ya get bucked off, get back on
                    • Geezer
                      • May 2003
                      • 2985
                      • Willamina, Oregon 97229
                      I had a set of Uni pods on the Mongrel and I really liked them. They were much better than the Parts N more ones that I think I still have in a box somewhere...
                      Geezer
