look what i found....
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    looks like someone put whiskey and sh*t in my brake system...
    yummy........
    1980 gs1000g "stock"
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    another one....
      Looks like your in for a strip and clean!
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        I use a cup holder for my coffee you should try it
        That's been in there for a few years for sure.
        BDF Special
          Shoot, that's a clean one... Most neglected ones I've run into have chunks of 'stuff' in there...
            Give it a taste and see if you can tell us when it was brewed!!
            After pumpin gout the muckiest of it, here is what was in Banshee when I got her...
            Not quite the balls of schtuff that Ras found when someone had mixed 4 and 5 together though.
            Highly recommend a complete dismantle of the entire system and clean it lines and fittings and all.
            • lee_dutcher
              • Apr 2009
              • 822
              • mason city iowa
              well there was some grey putty stuff on the bottom of the mc thats what i was trying to show in one pic...well i got some brakelines coming from hel so im good there but as for cleaning the mc. should i just spray some carb cleaner thru there and be done with it because after taking the diaphragm out i dont see screws or anything to disasemble...
                The reservoir is a twist and pull to remove. There is an oring in under there. Also pull the plunger out and clean inside as well.
                • ThrottleJunky
                  • Jan 2011
                  • 183
                  • PNW
                  Mine was that color but chunky, too. I completely disassembled the entire system, including removing the caliper pistons and seals, and cleaned every single inch.
                  1980 XS1100G. Work in progress.
                  1980 XS1100G. 2nd work in progress.
                  • brcree
                    • Mar 2010
                    • 388
                    • S.C.
                    Brakes
                    Yuuuuk......all these are great suggestions! I found nothing but rust in mine (front & back ) res.. Since brake fluid attracts water you should change it on a reg. basis.
                    At this time:
                    1985 Goldwing Innr.
                    1976 cb 750 cafe racer
                    2007 vtx 1300
                    81 sx 1100 s h
                    81 sx 400 special
                      I wouldn't use carb cleaner, I'd use brake cleaner, safe on rubber parts pretty sure.
                      • brcree
                        • Mar 2010
                        • 388
                        • S.C.
                        brakes
                        I agree with bikerphil.....
                        At this time:
                        1985 Goldwing Innr.
                        2007 vtx 1300
                        81 sx 1100 s h
                        81 sx 400 special
                        • lee_dutcher
                          • Apr 2009
                          • 822
                          • mason city iowa
                          gotcha...it warming up so i have to rush to get her together. still got to paint and install the hel and im done for a while]
                          • XSive Okie
                            • Jun 2010
                            • 281
                            • Enid, OK
                            And brake cleaner completely evaporates leaving no oily residue.
                            Richard
                            '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
                            '02 Honda VTX1800C
                            • cywelchjr
                              XS-XJ Super Guru(Deceased)
                              • 4450
                              • Sacramento, CA
                              While carb cleaner does that part too, it's the damage to rubber brake parts that would worry me, and brake cleaner is made for cleaning those parts. But, with the exception of the brake lines, I was taught in auto shop to use hot soapy water followed by a thorough drying on brake parts, as that does a better job of cleaning than the brake cleaner. For that matter, the hot soapy water follow by brake cleaner works cause the brake cleaner will help get the water out/off of the parts, but don't get water into the lines, you may have a hard time getting it out of them, everything else it's the best way.
