Last summer when i adjusted the valves, i had a problem with the front center bolt on the cover. This is on my 80 MNS. I loosened the bolt, but could not get it out past the cross bar just above it. I ended up having to cut the bolt, and replaced it with a piece of allthread, and nuts and washers. I looked everything over up front and could not find a reason for this. There didn't appear to be any sign of things being bent. No cracked paint or anything. Has any one came accross this problem, and if so, what did you do to correct it?
Cam cover mounting (valve cover)
1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!Tags: None -
yep that front bolt is a bugger to get out,
the only way i know is to loosen the bolt leaving it in
the valve cover, once all the other bolts are out u can lift
the valve cover and remove the bolt, ive tried
using a smaller bolt but the thread wasnt long enuff to hold it down
without it either coming loose or leaking.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
Yep, it ends up rubbing on the frame every time for me to. I like your solution, only, I would think the valve cover will not come off over the stud. So if/when you need to pull it off again, you will need to pull the stud out before you pull the valve cover.Life is what happens while your planning everything else!
78 XS750Comment
I think I remember reading about folks removing the engine frame bolt, either the back one or front one, and then being able to tilt the engine to get access to that bolt!? But a lot of trouble for sure...friggin' engineers oopsed on that one!
T.C.T. C. Gresham
Apparently I am the odd one out here. That never caused me a problem when removing.the.cover.Nathan
Theodore RooseveltComment
might be the later model bikes that have
the issue nate.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
When i figure a solution out, ill let every one know. Could cut that front brace! Ya right bob. Go ahead kill yourself.1980 XS1100LG Midnight
A cold beer and another one!Comment
