Cam cover mounting (valve cover)
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    Last summer when i adjusted the valves, i had a problem with the front center bolt on the cover. This is on my 80 MNS. I loosened the bolt, but could not get it out past the cross bar just above it. I ended up having to cut the bolt, and replaced it with a piece of allthread, and nuts and washers. I looked everything over up front and could not find a reason for this. There didn't appear to be any sign of things being bent. No cracked paint or anything. Has any one came accross this problem, and if so, what did you do to correct it?
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
  • petejw
    • 2269
    • sydney australia
    yep that front bolt is a bugger to get out,
    the only way i know is to loosen the bolt leaving it in
    the valve cover, once all the other bolts are out u can lift
    the valve cover and remove the bolt, ive tried
    using a smaller bolt but the thread wasnt long enuff to hold it down
    without it either coming loose or leaking.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      Yep, it ends up rubbing on the frame every time for me to. I like your solution, only, I would think the valve cover will not come off over the stud. So if/when you need to pull it off again, you will need to pull the stud out before you pull the valve cover.
        I think I remember reading about folks removing the engine frame bolt, either the back one or front one, and then being able to tilt the engine to get access to that bolt!? But a lot of trouble for sure...friggin' engineers oopsed on that one!
          Apparently I am the odd one out here. That never caused me a problem when removing.the.cover.
          • petejw
            • 2269
            • sydney australia
            might be the later model bikes that have
            the issue nate.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • XS1100 Newbie
              • Jun 2009
              • 1106
              When i figure a solution out, ill let every one know. Could cut that front brace! Ya right bob. Go ahead kill yourself.
              • DAVINCI
                • Jan 2011
                • 1048
                • Cedar Mountain, NC
                No trouble on the standards, maybe a bit different on the special frames?
                  IIRC I had to remove the horn bracket to get at the valve cover. I was then able to just loosen that one front screw, and pull the cover.
