Another carb folly
  • Stuckinmud15
    • Feb 2011
    • 64
    • Cheektowaga, NY
    Another carb folly
    When cleaning the carbs I soaked all of the seats (the brass things with the little screen filters on them) in carb cleaner...was that a bad idea? because it seems that all of the rubber o-rings on them have swelled up and they wont fit back into the holes, and they are very brittle. I took them all off. I need to get new ones obviously, anyone have a part number for the o-rings?
    2007 Yamaha r6
    81SH
    • 3193
    I just took one of the seats to my local NAPA and they had o-rings that fit. No special rings required other than fuel resistant.
      As mentioned, a good auto parts store should be able to match them up. Or Bikebandit, $3.82 a pop.
      • petejw
        • 2269
        • sydney australia
        the boys have u covered with the 'o' rings,
        if uve had them sitting in carb cleaner might
        not hurt to get a q tip dibbed in a bit of polish
        and cleaning the inside of the seat up where the
        needle is going to sit.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • Stuckinmud15
          • Feb 2011
          • 64
          • Cheektowaga, NY
          Sounds good, I think I also need some new needles, the rubber "cone" on the tip of the one is worn down to the point where metal is showing. Only on one though, should I replace them all for good measure or just the one?
          2007 Yamaha r6
          81SH
            Given what it takes to pull the carbs off, and get back into the float bowls, and the issues that develop when those valves leak like possible fire I think I would go ahead and replace all four while your in there.
            • Stuckinmud15
              • Feb 2011
              • 64
              • Cheektowaga, NY
              10-4 lol don't want fire
              2007 Yamaha r6
              81SH
              • Redshirt
                • Feb 2011
                • 142
                • Titusville, Fla.
                rubber tip? metal showing? Am I missing something? My needles are all brass. Me no want firez.
                79 Special
                2012 FJR1300
                78 E (project. Clutch problems from PO) Must sell
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  The older model carbs use all metal needle valves, but the later model carbs use carbs with viton tipped needles, which look like rubber. This seals better and actually tends to last longer, but when they wear out, they are REALLY worn out.
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    • Cedar Mountain, NC
                    Those with older metal needle set-ups can upgrade to the rubber-tipped valves. XV920 , IIRC. BTW, this is only for the screw-in valves.
                    • Stuckinmud15
                      • Feb 2011
                      • 64
                      • Cheektowaga, NY
                      Can someone suggest a good site to order carb parts from?
                      2007 Yamaha r6
                      81SH
                        A seller on ebay, here is his ebay store.
                        http://stores.ebay.com/georgefixsmotorcycleparts
