No, its not going to be much of a difference. But we have one person here who said he tried it and it did make a noticable difference.
Front Air Command
Different compression load on each fork.............hardly likely unless your using a rubber axle shaft. Fork brace or not, there both tied together by the axle. Now individually aired and the difference between the two forks may cause the bike to handle a bit strange. No air involved, but for an example to prove a point the Honda ST and Wing have hydraulic dampening on the left fork ONLY which also cantains the anti-dive valve internally at the bottom of fork. Right and left fork both dampen on rebound. Imagine this off-sets the location of rear mono-shock which is located on the right-side swing-arm. Whoever may believe that a left or right load side affects air pressure between the forks definitely has another issue going on with the suspension or tires, or both period.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
as i said, ive never done it, but one of the fellars
on the aussie site has and thats what he told me,
i was just relaying the story from some1 that had
experience with it.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
There is a device on another bike like this an that is a yamaha venture royale, load leveling air system, but alot of people that have these like my self just do away with them and go to the progressive springs that work better in the first place, but if ya want more bells and bangs on your bike here ya go, just my two cents worth1979 xs1100 f
142 main, 45 pilot, Jardeen crosover 4/2, no air box
floats @ 25.7
1979 xs1100 F
1978 gl 1000 goldwing
1981 gl 1100 goldwing
!986 venture royale 1300
Just an ol long haired country boy, come to town to spend some egg money
when ya get bucked off, get back on
It's not a big deal but if you lay down the bike the fork oil can flow from one fork to the other through the crossover line.-- Scott
Thanks For all your thoughts.
I'm not even going to bother with it.Four wheels move your body, two wheels move your soul.
1980 XS 1100SG
Dyna 3 Ohm Hi Output Coils
Pod Filters
DynoJet Kit
T.C.'s Fuse Block
V-Max Auto CCT
at least it brought up some good discussion.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
