Front Air Command
    No, its not going to be much of a difference. But we have one person here who said he tried it and it did make a noticable difference.
      Different compression load on each fork.............hardly likely unless your using a rubber axle shaft. Fork brace or not, there both tied together by the axle. Now individually aired and the difference between the two forks may cause the bike to handle a bit strange. No air involved, but for an example to prove a point the Honda ST and Wing have hydraulic dampening on the left fork ONLY which also cantains the anti-dive valve internally at the bottom of fork. Right and left fork both dampen on rebound. Imagine this off-sets the location of rear mono-shock which is located on the right-side swing-arm. Whoever may believe that a left or right load side affects air pressure between the forks definitely has another issue going on with the suspension or tires, or both period.
      • petejw
        • 2269
        • sydney australia
        as i said, ive never done it, but one of the fellars
        on the aussie site has and thats what he told me,
        i was just relaying the story from some1 that had
        experience with it.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • cowboybob998
          • Mar 2009
          • 371
          • KC MO
          There is a device on another bike like this an that is a yamaha venture royale, load leveling air system, but alot of people that have these like my self just do away with them and go to the progressive springs that work better in the first place, but if ya want more bells and bangs on your bike here ya go, just my two cents worth
          1979 xs1100 f
          142 main, 45 pilot, Jardeen crosover 4/2, no air box
          floats @ 25.7
          1979 xs1100 F
          1978 gl 1000 goldwing
          1981 gl 1100 goldwing
          !986 venture royale 1300
          Just an ol long haired country boy, come to town to spend some egg money
          when ya get bucked off, get back on
            It's not a big deal but if you lay down the bike the fork oil can flow from one fork to the other through the crossover line.
            • MrOzz
              • Aug 2008
              • 782
              • Massachusetts
              Thanks For all your thoughts.
              I'm not even going to bother with it.
              1980 XS 1100SG
              Dyna 3 Ohm Hi Output Coils
              Pod Filters
              DynoJet Kit
              T.C.'s Fuse Block
              V-Max Auto CCT
              • petejw
                • 2269
                • sydney australia
                lol
                at least it brought up some good discussion.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
