Originally posted by b.walker5
View Post
And before you rush off to radio shack, bear in mind these can get hot, so don't use one rated for less than 25 watts, 50 watts would be much better, with a 100 watt unit being bullerprooof. These will be dissapating the equivilent wattage as heat, so a 25 watt 6 ohm resistor for a 27 watt load will be operating above 100%. Also don't install it where it could melt anything in contact with it...
But if you're doing this to 'save power', don't; you'll be using the same amount, just in a different way. To save amps, you'll have to give up the self-cancel feature.
