Probably A Stupid Question, But I'm Gonna Ask It Anyway
  • Kit
    • Nov 2010
    • 201
    • Oregon
    Is there any way to estimate the miles on an engine? If so, I imagine it would have to be disassembled to make an accurate assesment. Mine had just over 26,000 on the odometer when I bought it, but I have a hard time believing that it hasn't turned over at least once. If they are original miles, then the previous owners have not taken very good care of her.
    XS1100SG - Obsession
    Like I told my last wife, I says, "Honey, I never drive faster than I can see. Besides that, it's all in the reflexes."
    -- Jack Burton
    Do a compression check after a valve adjustment and it should give you an idea of the engine condition. My MNS had 21K when I bought it 2.5 years ago. It had been parked for many years, then someone tried to make it look good, and got it running well.
    If you have less than 5% difference between readings, you should have a good engine. Just remember you need the throttle wide open to do a proper compression check.
      This won't directly relate to the motor, but checking other places on the bike can give you an idea of total mileage. Look at pivot points; clutch/brake levers, side stand, rear brake pedal, throttle sleeve. If these are worn to where there's significant play, yeah, you may want to put a 1 in front of that mileage. Not sure-fire, but can sometimes give a decent indication.
      • Kit
        • Nov 2010
        • 201
        • Oregon
        Thanks guys, I'll check those.
        -- Jack Burton
        • strom
          • 1577
          • Slovenia, EU
          When I got my 78E I had no idea of the milage.
          Clock said 66000 km.
          The condition... could be abused for 66k, 166k or 266k. No idea.
          I did replace a bunch of stuff and decided, it didnt even matter. Its just one of those engines that cannot be broken if properly serviced (except the gearbox) and if it is, it is almost always fixable. Same as a guzzi
          • 11Rider
            • Aug 2010
            • 331
            Footpegs are a good thing to look at too.
            '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
            Purrs like a kitten, runs like a scalded cat
              If the PO wasn't an aggressive rider though they may not scrape the pegs, but could have high miles though.
              • Kit
                • Nov 2010
                • 201
                • Oregon
                You're right, Strom. It really doesn't matter in the grand scheme of things. It's just something I'm curious about, is all.
                Also, it would be interesting to me to find out some of the history of my bike. I've Googled my VIN just for the hell of it, but nothing comes up. Didn't really expect it to, though.
                -- Jack Burton
                • Kit
                  • Nov 2010
                  • 201
                  • Oregon
                  Plus, this bike has been laid down on both sides, so there's no way of knowing if the damage is from that, or from the twisties.
                  -- Jack Burton
                  • planedick
                    • Mar 2005
                    • 2068
                    • Yorba Linda, California
                    High mileage
                    I know for sure mine has over 100,000 miles on it with no rebuild and now has 150 lbs compression straight accross. I think with these jewels, it would be really hard to find out without knowing all the po's and the complete history. You won't find many of the old HD's that hold up as well for sure, or even Hondas for that matter.
                    Drilled airbox
                    Tkat fork brace
                    Hardly mufflers
                    late model carbs
                    Newer style fuses
                    Oil pressure guage
                    Custom security system
                    Stainless braid brake lines
                    • 11Rider
                      • Aug 2010
                      • 331
                      I was thinking of the rubber part on top. You're constantly shifting and using the rear brake which means movement of your boots. I've noticed that on higher mileage bikes the rubber (expecially the outer part) has noticeable wear on it, kinda like the edge of the brake pedal on a car. Just onother piece of evidence to look consider If the rubber parts of the footpegs look anything close to new, I highly doubt the odo has gone around once, let alone twice. Also, check the underside of the frame. How much paint is chipped off is somewhat of an indicator. Mine has 7500 miles on it and the frame rails underneath are almost perfect.
                      • Kit
                        • Nov 2010
                        • 201
                        • Oregon
                        I see what you mean now. Good idea, thanks.
                        -- Jack Burton
                          That makes sense
                          • cywelchjr
                            XS-XJ Super Guru(Deceased)
                            • 4450
                            • Sacramento, CA
                            That does make sense. The rubber on mine was worn almost completely away on one side and was worn and gone on the other. Then I found a set of XJ pegs in very good condition and put them on and that made it look much nicer. That's one of the little things taht make me think mine is at just under 200k miles rather than just under 100k miles. Just lots of little things like that.
                            • shadowman
                              • Dec 2010
                              • 30
                              • Newcastle Ontario
                              The rubber on the footpegs is a good indicator, but keep in mind they are easily replaced. Mine look mint, and my odometer reads less than 20k. I just can't believe that of a 30 year old bike. My 2008 GSX650F, that I bought brand new in 2009, has almost 30k on it, and the rubber on the footpegs is worn significantly.
                              1981 Special- currently under construction
