Brake lines
    Yep, I bought a set for Thunderstruck (pre-wreck and parts bike) and had the brake systems pulled off of Banshee for cleaning when they arrived. So I compared the lines (since both are SH models). On the special models, the line from the front MC to the splitter has the ends turned 90 degrees offset. Same for the rear brake line. None of the lines in the kit have a 90 degree offset. So I wrote to him next day, said I do not think they will fit and explained the ends situation, but have not tried them. He said no problem, try them when I have time and he will take care of any issues.
    So a week or two later perhaps it warmed up and I went to change them out. Only way to get the lines from the MC to work is to remove the MC, hook the line up to it and use the MC for the leverage to twist the line and remount the MC. Same for front and back lines. Now, I am a risk taker to some extent, but I do not like the thought of all that torque on my brake lines just trying to twist the line out of its end while I am riding at 70 on the superslab or through some twisties. So I wrote to him again. He said send the lines back and he will replace them. Well....after many months of emails and ebay messages and filling out his selection sheet from the mfg of the lines to give him the exact fittings and layout of the lines including lengths, I have yet to this day to receive the lines. I have sent several emails and several ebay messages asking if he got my lines and where the replacements are. No responses form him. So, I got TWO SS brake lines for the $80 price tag. And alot of hassle.
    Now, several other folks here have bought the lines and had them work. They may have non stock (buckhorn) bars, I was using stock bars. They may have standards, and the lines should work for a standard up front as the MC is not turned as far. So as the old saying goes YMMV. Obviously, I would not ask the him for change of a dollar let alone buy anything from him again.
    • petejw
      • 2269
      • sydney australia
      thanx for the info, dgxser,
      i just bought them, ill let u guys know
      how they fit.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • Eveready1100
        • 539
        Hi guys,
        I bought a set a few months ago and though the fronts fitted ok, the rear line had the fittings mounted straight instead of the required 90 degree twist so was unusable.
        Also be careful what you ask for. I ordered a set to suit a Standard as I have low Sport bars on the bike. The MC line is about 4" too long due to the difference in the bar height so make sure you stipulate whether the kit is for a Special, Standard, or Sport as there is a lot of variation in the length of the lines. I did get the excess line hidden behind the fairing but it looks awful with it off.
        • redbone
          • Oct 2007
          • 244
          • Waynesboro pa
          boy...am i glad i read this thread. i was just gonna post a message asking where is a good place to get front brake lines for a 1980 mns. never thought it could be such a headache! never imagined they were so $$ either. will continue my home work on this issue.
          redbone
          testing 1-2-3
          1980 1100 mns
            Bremzen
            Has anyone here tried BREMZEN? Will I have to be the guinea pig? The price for a complete set of lines for my bike looks attractive. They offer sintered pads for the Special as well.
              It's still 150 for the whole set. Nothing special about the price.
              • redbone
                • Oct 2007
                • 244
                • Waynesboro pa
                anyone know if the front brake line kit from a 81 special will fit an 80 special???
                testing 1-2-3
                1980 1100 mns
                  80 & 81 Specials are the same.
