Brake lines
  • bg241ihc
    • 58
    Brake lines
    I have a source for simple black Teflon/stainless brake lines for the 1980 XS1100G and whichever models that would be the same. What would be a good/fair price to ask?
    I would have a bunch made up and sell them for $160.00 for a front/rear set if there was a resonable demand.
    The rear would be a straight line from master to wheel cylinder eliminating the steel coupling currently in between the two flexible lines.
    Kawasaki 74 XL400S, 83 550 GPz
    Honda 86 GL1200, 80 XL500S, 82 750 Nighthawk
    Yamaha 78 XS1100E, 80 XS1100G, 92 YZ80
    Suzuki 82 GS650L
  • figman
    • Mar 2009
    • 103
    • Asheboro, NC
    I would be interested if they will fit a 1978 Standard.
    current bikes:
    1983 GS 1100E
    2009 Kaw Vulcan 1700 Classic
    past bikes:
    1978 XS 1100
    1994 FZR 600
    1984 V65 Sabre
    1973 CB 750
    1974 CB 750
    1979 KZ 750 twin
    1977 CB 550
    1983 XJ 750 Seca
    1981 900 super sport
    too many others to list
    • benxs1100
      • 92
      • Somerset, Pa
      160 bucks sounds pretty expensive compared to what you can get them for from coastguard on ebay.
      '79 XS11 Special
      MikeXS Pods
      Green Coils
        Hey there BG,
        Not wanting to put a damper on your plans, but as an example www.helusa.com sells 3 line kits for $147.00. The front lines of ours do not have to be 3 lines, but can be 2 lines all the way from the MC to the calipers without the use of the junction behind the fork name plate.
        I had the Craig( fellow at helusa) make a custom set for me which also used a single line for the rear without the metal section. And I was able to get GREEN colored ones to match/compliment my paint scheme.
        So..just saying that you might want to check around for what folks can get and for what prices so you can be competitive! JAT!
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          I'd say TC has a good point. There are sources that go for less already, and HELUSA as I understand it is pretty much a name brand.
          Now personally I wouldn't go with the only 2 lines up front thing, I kinda like the single line down to the triples and splitting there, but that's just a personal preference not a technical thing. I do like the thought of getting rid of the hardline in the back, but my back brake works so well anyways that I can't see bothering to replace it, just the fronts.
          • bg241ihc
            • 58
            Thanks for the feedback. I will check with the manufacturer and see what kind of price break can be had at various quantity levels. The price I paid was for a single set first time he made them @ $140 my cost.
            Suzuki 82 GS650L
            • petejw
              • 2269
              • sydney australia
              theres a guy selling them atm for just
              under $110 plus shipping.
              http://cgi.ebay.com/ebaymotors/Yamah...Q5fAccessories
              and this guy is cheaper again
              http://cgi.ebay.com/ebaymotors/Stain...Q5fAccessories
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • cywelchjr
                • 4450
                • Sacramento, CA
                The top link is brake lines for the specials, and the XJ's from my reading of the listing. The second I'm not sure on, it might be for either one, but it doesn't specify. I forget but with the lines from coastguard1975 they are a bit of a problem either with standards or specials, having something to do with the orientation of the end connectors.
                • petejw
                  • 2269
                  • sydney australia
                  hey cy,
                  not sure what ur point is? :-)
                  i contacted coastgaud last nite, he'll sell the front brake
                  line for either the special (21inch) long or the standard (17 inch)
                  long for his stated price. not sure about his fittings,
                  maybe some1 who has bought them previously can chime in.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • tinman905
                    • Aug 2007
                    • 946
                    • Orangeville,Ontario ,Canada
                    hey cy,
                    I may be mistaken but I thought there was someone here that had issuse with Coastguard . Bad costumer service??????
                    BDF Special
                    • petejw
                      • 2269
                      • sydney australia
                      he's returned my messages quickly and his feed back is pretty good,
                      but yeah, if any1 has had problems dealing with him, it would
                      be good to know.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • cywelchjr
                        • 4450
                        • Sacramento, CA
                        hey cy,
                        Someone on here got them and found that the ends are not at the right angles to go on easily either for the special or for the standard. They can be fitted to the bike, but it takes a bit of work to do it IIRC. I'll probably get mine from him when I do that, but I'm just keeping in mind that for one of the models there was more work getting them on than there should have been.
                        Now this might have been fixed by now, but I've not heard anything else on the issue.
                        • petejw
                          • 2269
                          • sydney australia
                          no worries cy,
                          ill be getting them for my sport,
                          if there are any problems with them ill
                          let u all know.
                          they are a good price tho.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • cywelchjr
                            • 4450
                            • Sacramento, CA
                            They are that, and as much lower than any other vender price wise, it's probably worth a little cursing while installing them.
                              I think it was dgxser that had an issue with the lines from him?
