What SEATS from other XS bikes can I put on my XS11 GS?
Just cause the title says its an 80 and you vin (which vin by the way, engine or steering neck vin) matches it doesn't necessarily mean its an 80. check your steering neck vin against the list here. then you will know for sure what you need.
xs11.com/faqs/153-serial-numbersmodel-designationsfactory-colors.htmlNathan
Theodore RooseveltComment
It's always possible the previous owner changed the seat over to a 79. Have a look at your right side clutch cover , if it has a splined shaft for a kick starter just above your foot peg than your engine is a 79 and if your numbers match then you have a 79 . My ownership states mine is a 80 G but it is a SG things can get mixed up over time.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
It's the frame that matters. the engine does not matter, it could be any year. you need to compare the neck vin to that list in the link. then you will know what year and model seat you need to look for.Nathan
lol!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!it's always possible the previous owner changed the seat over to a 79. Have a look at your right side clutch cover , if it has a splined shaft for a kick starter just above your foot peg than your engine is a 79 and if your numbers match then you have a 79 . My ownership states mine is a 80 g but it is a sg things can get mixed up over time.BDF Special
Didn't read all the way through before I responded. its just pretty common that people tell others to look at something other than the vins to tell what they have, and that gets things muddled.
Sorry tinman.Nathan
A bolt on option for the 79 SF is the Oceanic RH or the UK / Euro 5k7 Sport seat. They fit straight on to an SF Special.
https://
*"The Keg"- UC torana hubs, XS11 discs, Tokico 4 spot calipersComment
seat
I took a seat from an 81 MNS, trimmed the area above the side covers to an almost straight line, and put it on my 79 Special. Had to loosen the cover and cut the sheet metal, re-install the cover, and have a very comfy seat, and everything fits up nicely. If you need a pan for an SF, ANY special pan can be trimmed to clear the side covers.Last edited by rover; 01-17-2011, 10:43 AM.put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
79 XS 650S (gone to MC heaven)
76 CB 750 (gone to MC heaven)
rover has spokenComment
seat answer correction please delete
I took a seat from an 81 MNS, trimmed the area above the side covers to an almost straight line, and put it on my 79 Special. Had to loosen the cover and cut the sheet metal, re-install the cover, and have a very comfy seat, and everything fits up nicely. If you need a pan for an SF, ANY special pan can be trimmed to clear the side covers.Last edited by rover; 01-17-2011, 10:46 AM.put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
