What SEATS from other XS bikes can I put on my XS11 GS?
  • jshepard935
    • Jun 2010
    • 26
    The first picture you show is a '79 Special - note the non-slotted brake rotors and the thin grab bar behind the seat. The second picture is an '80 Midnight Special. In '80 and '81, both the Specials and Midnight Specials had the same seat construction (and grab bar), with slightly different stitching on the cover for the Midnights.
    If what you have is the first picture, you have an SF, NOT an SG, and you will be searching for a new seat pan for a while! They only fit that one bike, and are VERY hard to come by.
    i'm certain it's 1980.. title matches serial number, title says 1980.. perhaps the previous owner left me with a custom seat? it's definitely the same shape, albeit with slightly different stitching.. interesting..
      Just cause the title says its an 80 and you vin (which vin by the way, engine or steering neck vin) matches it doesn't necessarily mean its an 80. check your steering neck vin against the list here. then you will know for sure what you need.
      xs11.com/faqs/153-serial-numbersmodel-designationsfactory-colors.html
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        It's always possible the previous owner changed the seat over to a 79. Have a look at your right side clutch cover , if it has a splined shaft for a kick starter just above your foot peg than your engine is a 79 and if your numbers match then you have a 79 . My ownership states mine is a 80 G but it is a SG things can get mixed up over time.
        BDF Special
          It's the frame that matters. the engine does not matter, it could be any year. you need to compare the neck vin to that list in the link. then you will know what year and model seat you need to look for.
          • tinman905
            • Aug 2007
            • 946
            Originally posted by tinman905
            it's always possible the previous owner changed the seat over to a 79. Have a look at your right side clutch cover , if it has a splined shaft for a kick starter just above your foot peg than your engine is a 79 and if your numbers match then you have a 79 . My ownership states mine is a 80 g but it is a sg things can get mixed up over time.
            lol!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
            BDF Special
              Didn't read all the way through before I responded. its just pretty common that people tell others to look at something other than the vins to tell what they have, and that gets things muddled.
              Sorry tinman.
              • Eveready1100
                • 539
                A bolt on option for the 79 SF is the Oceanic RH or the UK / Euro 5k7 Sport seat. They fit straight on to an SF Special.
                https://
                • rover
                  • Jan 2004
                  • 765
                  • central WI (715)
                  seat
                  I took a seat from an 81 MNS, trimmed the area above the side covers to an almost straight line, and put it on my 79 Special. Had to loosen the cover and cut the sheet metal, re-install the cover, and have a very comfy seat, and everything fits up nicely. If you need a pan for an SF, ANY special pan can be trimmed to clear the side covers.
                  79 F (Blueballs)
                  79 SF (Redbutt)
                  81 LH (organ donor)
                  76 CB 750 (gone to MC heaven)
                  rover has spoken
                  • rover
                    • Jan 2004
                    • 765
                    • central WI (715)
                    seat answer correction please delete
                    79 F (Blueballs)
                    79 SF (Redbutt)
                    81 LH (organ donor)
                    rover has spoken
