I took off the rear wheel of my 1979 Standard XS1100, checked and greased the splines and now I am not quite sure if I assembled everything in the right order
I should have taken pictures, thought that I should be able to see how things are assembled in the manual, but I want to make sure that I did it right.
This is how it looks now:
http://
Is this OK?
I also have a hard time getting the axle in; there are about 2 inches more to go. Should I lift the wheel and "wiggle" things in place, use a hammer...?
I was also wondering, what the best way is to torque the 4 nuts correctly that hold the final gear case. With the wheel in place there is very little room for at least two of the nuts.
Thanks in advance for your help!
Armin
http://
Is this OK?
Armin
