is there any alternitive nuts for the head pipes? or am i going have to pay my local yamaha dealer 5 bucks each? thanks!
header nuts
Tags: None
nuts
Blknbyrd, You should be able to find them at a fastner place. You may have to get toward Greensboro or Charlotte to find one but probably be around a quarter apiece. Are you close to Carolina Skydiving? I come that way occasionally, not for jumping ,just visiting. Family there.POTTS CREEK EXPRESS
IF YOU AINT THE LEAD DOG
THE VIEW IS ALWAYS THE SAME
1980 G Full Dresser -
I would think Fastenal or Gainer should have them or be able to get them, or most other fasteners places.Nathan
Theodore RooseveltComment
Just do yourself a favor and DON'T use stainless. I made that mistake only to find out that they discolor horribly.'81 XS1100 SH
Sep. 12th 2015
RIPComment
I have some used ones sitting in a pile in my garage. Yours for shipping. I'm not sure if I have a complete set though. How many you need?1980 XS850SG - Sold
-H. FordComment
If you still have OEM exhaust, standard nuts are hard to get a wrench on inside that recess in the flange. Ask for 'coupling nuts' as these are about 3X longer. But they may not much cheaper; the metric versions are considerably more expensive than SAE for some reason. McMaster-Carr lists them for about $3 each if you can't find them locally.Fast, Cheap, Reliable... Pick any two
Lucky bastard!
my Yamaha store charged me $8 each.
And no, ordinary hex nuts won't work in those flange recesses, that's why they used those Weird Harold socket nuts instead.
OK, you can pull the studs and use Allen screws instead but that'd put extra wear on the threads in the head.Fred Hill, S'toon
"The Flying Pumpkin"Comment
head nuts
bug i have all eight but they are rusty. how hard are they to get loose? any tricks to loosen them up? vanhump are you talking about swan creek airport? if so about five miles. can watch them jump on my front porch with binoculers. thanks to all for the infoComment
Soak them (or anything like that) with PB Blaster (NOT WD-40) and let it sit for a little bit. You can try adding heat after that (running the bike might work) and even beating on them a bit with a hammer. Once you get them off, you can use your favorite rust remover to clean them up, and even paint them if you like. Then, touch the studs with anti-sieze to prevent having to do this all over again next time.1980 XS850SG - Sold
-H. FordComment
You could use a thread tap to chase the threads it is a trick that I use on old rusty bolts and nuts to clean them up.'79 XS11SFComment
swan creek
That is it.POTTS CREEK EXPRESS
1980 G Full DresserComment
I used these: http://cgi.ebay.co.uk/M8-x-24mm-long...item230c4c542bXS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
header nuts
thanks for the link james those outta do the trick! vanhump let me know when you're down here and we'll meet up and talk yammer-hammer!!!Comment
Those are coupling nuts, and should be available without crossing the pond...
And remember the warning about SS... heat doesn't do good things to it.
