header nuts
  • bcknblkbird
    • Mar 2009
    • 124
    • jonesville nc
    header nuts
    is there any alternitive nuts for the head pipes? or am i going have to pay my local yamaha dealer 5 bucks each? thanks!
  • vanhump
    • Feb 2004
    • 142
    • the virginia mountains CRAIG COUNTY
    nuts
    Blknbyrd, You should be able to find them at a fastner place. You may have to get toward Greensboro or Charlotte to find one but probably be around a quarter apiece. Are you close to Carolina Skydiving? I come that way occasionally, not for jumping ,just visiting. Family there.
    POTTS CREEK EXPRESS
    IF YOU AINT THE LEAD DOG
    THE VIEW IS ALWAYS THE SAME
    1980 G Full Dresser
      I would think Fastenal or Gainer should have them or be able to get them, or most other fasteners places.
      • 81xsproject
        • 3185
        • Fortuna, CA
        Just do yourself a favor and DON'T use stainless. I made that mistake only to find out that they discolor horribly.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          Really? Huh, whoa thunk. Good to know!
            I have some used ones sitting in a pile in my garage. Yours for shipping. I'm not sure if I have a complete set though. How many you need?
              If you still have OEM exhaust, standard nuts are hard to get a wrench on inside that recess in the flange. Ask for 'coupling nuts' as these are about 3X longer. But they may not much cheaper; the metric versions are considerably more expensive than SAE for some reason. McMaster-Carr lists them for about $3 each if you can't find them locally.
                is there any alternative nuts for the head pipes? or am i going have to pay my local yamaha dealer 5 bucks each? thanks!
                Lucky bastard!
                my Yamaha store charged me $8 each.
                And no, ordinary hex nuts won't work in those flange recesses, that's why they used those Weird Harold socket nuts instead.
                OK, you can pull the studs and use Allen screws instead but that'd put extra wear on the threads in the head.
                • bcknblkbird
                  • Mar 2009
                  • 124
                  • jonesville nc
                  head nuts
                  bug i have all eight but they are rusty. how hard are they to get loose? any tricks to loosen them up? vanhump are you talking about swan creek airport? if so about five miles. can watch them jump on my front porch with binoculers. thanks to all for the info
                    Soak them (or anything like that) with PB Blaster (NOT WD-40) and let it sit for a little bit. You can try adding heat after that (running the bike might work) and even beating on them a bit with a hammer. Once you get them off, you can use your favorite rust remover to clean them up, and even paint them if you like. Then, touch the studs with anti-sieze to prevent having to do this all over again next time.
                    • trdriver71
                      • 360
                      • Edmonton Alberta
                      You could use a thread tap to chase the threads it is a trick that I use on old rusty bolts and nuts to clean them up.
                      '79 XS11SF
                      • vanhump
                        • Feb 2004
                        • 142
                        swan creek
                        That is it.
                        POTTS CREEK EXPRESS
                        1980 G Full Dresser
                        • James England
                          • 3039
                          • North of England
                          I used these: http://cgi.ebay.co.uk/M8-x-24mm-long...item230c4c542b
                          • bcknblkbird
                            • Mar 2009
                            • 124
                            • jonesville nc
                            header nuts
                            thanks for the link james those outta do the trick! vanhump let me know when you're down here and we'll meet up and talk yammer-hammer!!!
                              Those are coupling nuts, and should be available without crossing the pond...
                              And remember the warning about SS... heat doesn't do good things to it.
