oil filter bolt
  • OLY-XSer
    • Jun 2010
    • 46
    • Olympia, WA
    oil filter bolt
    does anyone know where i can find a cheap oil filter bolt. my bike is a 80sg 1100? can you use a oil filter bolt from a smaller xs bike of the same period? I think the yamaha shop wants about 70bucks for one. thanks for any help.
    1980 xs11sg
    16600 miles, soon to be a lot more
    stock headers with free flow exhaust
    mikes xs pods
    #45 pilot jets
    #130 main jets on 2 & 3
    #125 main jets on 1 & 4
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Try Andreas Weiss, he's on here and has lots of parts for sale.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
      IIRC, They sell them over at the Parts-n-more site.
      Yep....
      Vintage Honda, Yamaha, Kawasaki & Suzuki motorcycle parts. Find carburetor kits, brake parts and seals by model and year. Free USA & Canada shipping over $50.
      • Eveready1100
        • 539
        Just a note of caution using aftermarket filter bolts. There have been a number of cases of the Pressure relief valves jamming in some of the cheapie bolts available so make sure you check for correct operation of the valve before fitting it.
        • xs11lover
          • 1433
          • Montoursville Pa
          I'm pretty sure I have an xtra, if you have trouble.
          79 XS11 Special (Lazarus)
          79 DT 100
          • OLY-XSer
            • Jun 2010
            • 46
            • Olympia, WA
            thanks
            thanks for the help guys.
            1980 xs11sg
            mikes xs pods
            #45 pilot jets
            • prometheus578
              XS-XJ Super Guru (RESIGNED)
              • Aug 2004
              • 4012
              • Olympia , Wa.
              Whatsamatter... Bolt head stripped?
              Here's what ya do:
              1. Go to Tacoma Screw and buy a large, metric nut. Size...? Oh, maybe something that a 17mm socket/wrench would grab.
              2. Take oil filter bolt, large nut and a six pack of good beer (Let's not be cheap here with the bribe) and go to Zigler Welding downtown, (322 Capitol Way) or go to anyplace that makes trailer hitches and such.)
              3. Place the 6 pack on the counter... then place the large nut over the stripped bolt head and ask the counter guy if they could please fill in the hole with 'filler rod'.
              4. You now will have an oil filter bolt with a head that won't strip.
              (Make sure to remove the O-ring prior to welding. Might melt, ya know)
                Originally posted by prometheus578
                ... Go to Tacoma Screw and buy a large, metric nut. Size...? Oh, maybe something that a 17mm socket/wrench would grab...
                What? Has Olympia Supply gone out of business??
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  Hey, I used to go to Tacoma Screw when I needed oddball fasteners that I couldn't find anyplace else. Then I moved to a bigger town, that doesn't have anyplace like that.
                    This is where I go, they have nice stuff...lol
                    • cywelchjr
                      • 4450
                      • Sacramento, CA
                      Of course I'm fixing my potential filter bolt problem by installing a SOFA during my next oil change. Then I won't have to worry about it again.
                      • Crusty Snippets
                        • Sep 2010
                        • 428
                        • Gabriola BC
                        Tacoma
                        Here's what ya do:
                        Well this reminds me of two things.
                        One of the early loves of my life lived in Tacoma. Her name was Jamie, rode bikes. She would be about sixty now.
                        While looking at the POs receipts I noticed a work order that said the oil filter bolt was stripped.
                        Do not know for sure that it was fixed, other than the bike does not drip oil.
                        I guess I will find out.
                        Crusty
