My headlight doesn't come on either.last question of the evening. Any ideas on what exhaust that is?
My First Bike...What have I gotten myself into?
Also, BEFORE removing carb parts, use PLENTY of PB Blaster or your choice of penetrating oil, and no, WD-40 is not a good substitute.
Oh, the wicked ways of some POs. Banshee came to me without a fuse one in it. Everything form the main fuse on had been removed with the wires crimped together. The fuse box TopCat ( a moderator/member here) sells is the best I have seen for these bikes, and mounts up nicely as well. For $10 including connectors I think it is a great deal!! If you wanted, you can simply buy some stab in conncectors of the same size as the legs of the fuses and put those on the wires to just hook up to the fuses. Not as neat, but it does work. Fuses I think are a MUST!!
As to your headlight, on these bikes Yamaha implemented a "battery saving feature" that does not turn on the headlight until the engine is running. So if you do not get the engine to at least start, the headlight will not light up.
Hope That helps
DonLife is what happens while your planning everything else!
78 XS750Comment
Wow. Don You are the man. thanks for that info. I was thinking of doing the factory carbs just because I know what parts they need but I'm prolly going to need every piece for them. I think the dia's might be good but i doubt it. I'm going this weekend to see if the local bike graveyard can identify what they are off of.Comment
Tx500
"... I know back in 2002 nobody wanted to touch the TX500 I inherited because it was too old..."
WOW! A TX500! A very fast bike in its time. My buddy bought one new in 1974(?) and I still vividly remember him pulling up beside me as we cruised down the road (me on my 350 Harley) and yelling "Watch this!" He then fell off. To this day I have no idea what he was trying to show me.1980 XS 1100 Special
Mostly stock & original
Added Yamaha fairing (w/ 8-track!)
Torpedo bags
New paint (still) pending
Stainless brake lines
Tkat forkbrace
Coils from Honda 1000
Previous bikes:
1968(?) 350 Harley Davidson
1977 Yamaha 650Comment
Yeah, I still haven't put that one back together. The 2 carbs on it have been a problem since my dad bought it. He spent like $400 at a local shop in the 90's and it still never ran right. It's now been sitting in the garage for 20 years and needs everything replaced. That's why I bought this bike because at least it was recently running. I was totally thinking about throwing an xs650 motor in tx500 frame. I just know the DOHC motor in that bike is a PIA to work on.Comment
Sorry, couldn't resist.... LOLFast, Cheap, Reliable... Pick any two
Is there any difference between Special carbs and Standard carbs? Are there any recommended sellers?Comment
No differences, just the newer style and older style carbs. Georgefix on eBay OS the one to get parts from for the carbs.Nathan
ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
Theodore RooseveltComment
As stated, the Standard versus Special is no difference, there was a fairly in depth change in the styles from the 78-79 model to the 80-81 model. The ones you have look to be the 78-79 style from the pics.
If you want new carb kits, Georgefix is my first go to guy for carb parts. If you want a full set of carbs, I have a set of the 78-79 style fully apart and cleaned up nicely, just need to get the jets and I am upgrading the needle valves and seats to the XV920 type. Only problem with them is one float post is broken right in the middle of where the pin sits, half the seat for the pin is still there.
Honestly, for those who have this same location of break in the post, having worked on these and put the float in with the pin in like that, it is NOT going ANYWHERE and I would have no questions of loading those carbs in my bike as is and riding for the coast with it.Life is what happens while your planning everything else!
78 XS750Comment
havent read the whole thread
so if the carby question has been answered
i apoligise if not
those carbies are the zrx carb
they should have keihen cvk written
on the side
heres a pic of mine im messing around with atm
were they already fitted to the bike
or did they come as spares?pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
theres a few3 posts on these carbs
yamahnsolo has done the lastest one with a vid
of his running
heres a link
pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
They have been fitted to the bike. I just need to tap the hole where the needle valve goes. Also the scew that goes in the bottom of the bowl. Other than that they are in good shape.Comment
thats something i did 2 the carb
in an attempt to connect the vac advance.
not sure of the valve ur talking about
but ive put a universal choke cable on mine.
while u have them apart could u measure
the spring length for me, check out what main
and pilots jets u have as well tia.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
