My first project
    • 8919
    If you've lowered the front end a bit due to the clip ons, 11.5" is probably good. IIRC, stock height for the XS11 is 12 5/8".
      #47
      ...IIRC, stock height for the XS11 is 12 5/8"...
      ...and it's the same 12 5/8" for the XJ. Do remember that whatever you put on will compress about 3/4-1" when you sit on the bike, so check your fork sag and calculate accordingly...
      It's looking good!
      • stevestrom
        • 109
        • Abbotsford, BC
        #48
        Yeah, the front is lowered about 1 1/4" to accomodate the clip ons. I did put on a larger tire in the front so as to counter how much lowered the front end. I wanted to lower the back about 1" so that I would not be changing the factory dimensions of the bike too much. Sounds like the 11.5" shocks will work well then.
        • subike
          • 167
          • Christchurch New Zealand
          #49
          interested in where "under the tank" you placed the key,
          did you use the std ignition barrel? ( my key falls ot of mine )
          http://i139.photobucket.com/albums/q...e/DSC00009.jpg
          1980 XS1100 Std English Assembled, 378k miles
          In stock untouched contion.
          http://i139.photobucket.com/albums/q...e/seatside.jpg
          1979 XS1100F Std NZ new,
          Mikes XS coils
          Jardine 4-1
          Pod filters
          Harley Davidson Rear Fender
          Bullet signal lights
          Twin 75mm headlights
          Self made single seat
          • stevestrom
            • 109
            • Abbotsford, BC
            #50
            Since I redid the wiring harness and was changing the guages and handle bar set up, I wanted less clutter up by the handlebars. I thought about removing the key altogether and just having an on off switch, but since I already had the barrel with a key and it worked I opted to use it. Since I am not skilled at fabricating, any new key mount that I made would look like crap so I decided to shorten up all the wires and place the factory ignition barrel under the rear of the tank.
            I have it mounted to the hanger for the old airbox but since I am not going to be using the airbox it won't be in the way.
            • Electronhammer
              • 54
              • Central Illinois
              #51
              Coming along nicely. Curious though, what will be your method of getting the bike off of the table it is sitting on? I can think of several ways, but was curious as to how you plan on getting the bike back on the ground. BTW I really like the paint job on the engine.
              1980 CB750K
              • stevestrom
                • 109
                • Abbotsford, BC
                #52
                Yeah, I've been thinking about that too. Best that I can come up with right now is to use a low profile floor jack and lift one side of the stand (kickstand side of the bike). Take the legs off and lower it down, set the bike on the side stand and slide the wood out the other side.
                What were your thoughts?
                • Electronhammer
                  • 54
                  • Central Illinois
                  #53
                  Your idea might be the best idea. I would have to think about it for awhile. Are you pretty close to being finished? It's looking great.
                  1980 CB750K
                    #54
                    Not sure if you have access to what is needed or not, but you could use a strap around the neck of the frame and lift the front end up like in a wheelie. Have someone there to stabalize the bike and then move your stand and lower the bike back down.
                    • Electronhammer
                      • 54
                      • Central Illinois
                      #55
                      How about these: http://www.google.com/products/catal...d=0CFYQ8wIwAA#
                      1980 CB750K
                        • 8919
                        Just get a couple of your buds or neighbors to help you lift it off.
                          #57
                          Getting the bike off the stand?
                          I'm voting for 'E. J. Potter' style....
                          http://thekneeslider.com/archives/20...chigan-madman/
                          • stevestrom
                            • 109
                            • Abbotsford, BC
                            #58
                            Yeah!
                            I could get it facing out the garage, start her up, get the back wheel spinning and have a friend cut the legs off the stand with a chainsaw! I'll have the wife make the video instructional.
                            • stevestrom
                              • 109
                              • Abbotsford, BC
                              #59
                              Still have a way to go on it though. Grips, foot pegs, pods, and petcocks are coming in the mail (I am going to attempt to make my own rearsets). I've found a gas cap, throttle cable, clutch cable, and shifter off several doner bikes all for $25. Still need to rebuild the front master cylinder and all the calipers, get stainless brake lines, clean up and mount the headers and muffler. Also have to figure out brake light, signals, guages, not to mention attaching and recovering the old seat. I'll be using the old XJ shocks for a while untill I have enough money to buy some new ones (not interested in rebuilding them). So on top of all this I am still going to have to mess around with trying to get it tuned. FUN!
                              • Electronhammer
                                • 54
                                • Central Illinois
                                #60
                                Recover it from where? Is it in a pond or some other body of water? LOL I can't wait to see the finished product. Keep the pics coming.
                                1980 CB750K
