My first project
  • petejw
    • 2269
    • sydney australia
    great work,
    thats coming along very nicely.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      I would not recommend trying to use those fork tubes. With that level of pitting they will probably spring a leak within the first few times they compress, and you really don't want fork oil on your front brakes, and that's where it's almost guaranteed to go. These brakes are marginal when working right, when oil soaked they are almost useless. Forks aren't that bad if you shop around. I picked up a working set for a little over $100 when my seal blew and I couldn't get the caps off or get them apart to replace the seals.
      • stevestrom
        • 109
        • Abbotsford, BC
        Here are the rest of the tank pics. And some patches of pinholes. I turned the light out in the garage and put a flashlight in the tank so that I could see all the holes. Tapped around all the holes to make sure that the surrounding metal was solid and then filled them in. I lined the inside of the tank with POR15 after I patched all the holes and there was no leaking of anything. I am confident they are solid.
        Then came my first experience with Bondo.
        Now to add paint.
          Hi Steve,
          Great job on the tank. That filler sure is going to thow off some experts in the future
          • stevestrom
            • 109
            • Abbotsford, BC
            #35
            I didn't really want to use them but as I've said before I am doing this on the cheap for now and I can always pick some up later. As it sits I am just $600 into it at this point. Just buying the new things that I absolutly cannot reuse or that are safety issues like tires and brake lines.
            Thanks for the input though!
            • petejw
              • 2269
              • sydney australia
              #36
              that tank came up sweet.
              have u picked a colour for it yet?
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • Mathh
                • Nov 2006
                • 681
                • Beek, Netherlands
                #37
                great job! looking awesome already... the xs on yr desktop is from "rossifumi46", from the French club who is on the UK site as well, at least once in a while. Some pics there as well.
                MV Agusta Brutale 910R '06.
                Yamaha MT-09 Tracer '15 grey.
                • stevestrom
                  • 109
                  • Abbotsford, BC
                  #38
                  Yep, Red and white.
                  Looks kind of orange in this one. I think its the lighting.
                  • subike
                    • 167
                    • Christchurch New Zealand
                    #39
                    very loud, that tank conversion looks so much better painted, I like
                    http://i139.photobucket.com/albums/q...e/DSC00009.jpg
                    1980 XS1100 Std English Assembled, 378k miles
                    In stock untouched contion.
                    http://i139.photobucket.com/albums/q...e/seatside.jpg
                    1979 XS1100F Std NZ new,
                    Mikes XS coils
                    Jardine 4-1
                    Pod filters
                    Harley Davidson Rear Fender
                    Bullet signal lights
                    Twin 75mm headlights
                    Self made single seat
                      • 8794
                      That looks sweet. What bike are the clip-ons and switches from?
                      07 Triumph Tiger 1050
                      • stevestrom
                        • 109
                        • Abbotsford, BC
                        #41
                        The clip ons are aftermarket Tommaselli brand. I was worried about tank clearance with the clipons and these are pretty sweet; very adjustable. I do not hit the tank at all from lock to lock. The switches are factory XJ1100 switches. I just cleaned them up with the glass beader and through some clear coat on them.
                        The clip ons were a little pricy at $120, (Most expensive part of the bike so far) but I figured that it was worth it since the XJ triple tree can't take standard bars and and these ones are adjustable to account for clearance issues
                        • petejw
                          • 2269
                          • sydney australia
                          #42
                          that looks amazing,
                          the whole bike is coming
                          along very nicely,
                          mate ur a fast worker as well.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • stevestrom
                            • 109
                            • Abbotsford, BC
                            #43
                            that looks amazing,
                            along very nicely,
                            THanks.
                            I don't work that fast though. This progress has been made over the past 4 months. The last pictures are pretty much how the bike sits now with the exception of a crank case breather and the key relocated to under the tank. Just got new tires for it today so I should have a pic of those mounted up soon!
                            • stevestrom
                              • 109
                              • Abbotsford, BC
                              #44
                              Well I got the tires and wheels put on today. Anyone know what the length of the stock rear shock on the XJ is? I think that I am going to go with an 11.5" shock, that is what it is sitting at in these pictures.
                                #45
                                Coming along very nicely!! I think the XJ had the same rear shock length as the XS which I believe are 11.5" stock.
