Carb Boot Cutaway
    • 3193
    Carb Boot Cutaway
    I thought some members could be confused when we all talk about the carb boots having three layers. I have some old carb boots so I decided to cut them in half to see what is actually there. I was ever so suprised to find they are not what I expected at all. I decided to post a pic of the cut in half Carb boots so others could see what they look like. Here they are, I hope they help someone understand the concept and how they can in fact leak if the holes/cracks are in the right place.
  • Elevener
    • 608
    • small town in TEXAS
    Not quite how I pictured it from what I have heard. Thanks for the pics,
    Trapped in time. Surrounded by evil. Low on gas.
    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
      That was exactly what I was thinking. Thanks for the sacrifice
      • GARTHXS
        • 1631
        • Seattle
        I know its snowing up there but are you so bored that you have to cut stuff up. What's next an engine so you can show how the cct works?
        91 kwaka kz1000p
        Stock
        ( Insert clever quote here )
          • 3193
          Nope Just installed new ones on the 81LH so I had these to sacrifice is all...well that and a natural curiousity
          • Mr.Bill
            • Aug 2009
            • 118
            • Clarksburg Maryland
            And what you waited over 6 years to tell us of your findings
            1979 XS1100SF.
            "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
              • 3193
              I never even noticed the date was on those pictures. I had just replaced the camera batteries and when it wanted to set the date, I thought if I cancelled then it would not show. OOOPS
              • yamtom
                • 275
                • Midland Michigan
                what the,,,,,,
                Hi,
                I did not expect to see the white area at all, I am assuming that that is a separate type of rubber, perhaps put in as a strengthener in the mold before the rest of the rubber was poured..
                It looks like the most sensitive and or thin area is going to be right next to the carb attachment area, eh? That would also be an area where the viberating motion would be at its strongest too. Is anyone seeing that area as the area where most boots fail, if I can ask???
                Bikes Now.
                80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
                79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
                83 Yammi Venture with custom footboards, 20k miles.
                83 Yammi Venture parts bike
                99 Valkyrie shield and bags 37k miles like new
                08 ZX 14 Kawa Ninja 6k miles Sold
                  Originally posted by yamtom
                  Hi,
                  I think, but correct me if I am wrong Rasputin, the "white area" is metal and not just a different type of rubber. It is there to strengthen from collapsing due to vacuum or expansion due to backfire through the carbs, as well as a surface against the head to bolt on.
                  I am guessing the metal runs almost to where the carb lip would sit inside the boot. This then let's the rubber flex enough to get the carbs in and seal well. Would probably be pretty hard if the metal went all the way through to the end.
                    • 3193
                    Yes the "white area" is indeed just aluminum. It is just the flash from the camera that gives it the white color. The cracks that were in these were mostly just to the carb side of the metal area.
