found a jet kit for older carbs! i think.....
    What is it that changed so much that a person can't use the later model kits on the early model carbs?
    Other than the pilot jet no longer getting fuel through the mains, and couldn't that be plugged like the early 80 carbs were?
    • petejw
      • 2269
      • sydney australia
      hi nate,
      off hand, the slides are different between models and
      the mixture screws are different.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • yamahansolo
        • Aug 2007
        • 1113
        • jawga
        The main jets are also different. If you. Look up the 80+ ones they come with airjets and all the main jets are smaller... and the needle is diff.... I saved the needle number on the phone I'll have to get it later and post them
        79 xs11 standard
        8mm msd wires
        tkat fork brace...
        Fox shocks...
        mikes650 front fender
        led's gallore...
        renthal bars
        gold valve emulators
        vmax tensioner
        Rifle fairing
        • SFerinTEXAS
          • Jun 2006
          • 876
          Most likely the are no appreciable gains to be had by modding the early carbs. The 80 and up engines were de-tuned by law for emissions and as with anything else people came up with ways to undo those changes and the carbs were the single most effective and easiest way to do that. JMHO
          79SF
          XJ11
          78E
          • 81xsproject
            • 3185
            • Fortuna, CA
            I disagree. The only thing 'de-tuned' on later bikes were the cams and ignition timing.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              And compression, and tuned leaner (especially in Ca) to meet clean air standards. I agree though that the carbs are not a significant factor in the issue. I believe that the larger valves were supposed to make up at least in part for the de-tuning stuff, but it obviously didn't quite work.
