<rant> Hose clamps
  • Macamon
    • Aug 2009
    • 71
    • Los Angeles
    <rant> Hose clamps
    Man, I can't believe! I went to three different auto parts stores and couldn't come up with 16 corbin clips for my fuel system. These big chain stores have put the little guys out of business, and now the things you used to be able to walk in and ask John for are sold in blister packs for 8 times the price and you wind up buying a bunch of junk you don't need to get what you want.
    The only way I was able to find these was in a $7 combo pack that only had 5 per pack and you got 30 other clips that were of different sizes that you don't need </rant>
    "There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation." --HERBERT SPENCER
    Active: 1932 Ford Model A; XS1100SF (Just got 'er); XS1100SG; 2000 F250 Turbo Diesel; 2003 Ford Mustang
    Broken: 1999 Kawi Vulcan 750; 1998 Triumph Trophy 1200
    Gonners: XS1100SF (my first ride); '82 Honda CB900F (bored to 1123cc); '86 Kawasaki ZG1000
    I hear ya on that one! It's getting old fast!
      Hi Mac,
      my local bike store still sells hose clips by the each.
      But your rant segues back to the "ditch the octy" string.
      If you ditched your octy and ran a simple 2-line fuel set-up you'd only need 4 of the bastards.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        • Fort Myers, Florida
        Clamps
        Dont know if this is what you are looking for, deff not giving any oppinion on keeping or losing the "octy" just hope it helps out a fellow member
        http://cgi.ebay.com/ebaymotors/MIKUN...item1c15e6a8a7
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          I use 1/4" automotive fuel line and no clamps. No leaks, ever. I also did away with the octy.
          I plugged the 2 front (prime) nipples on the petcocks. Then ran the hoses from the petcocks to the 2 T's, from the T's to the carbs. This way I can run from either or both petcocks.
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
            Hi 4ME,
            Gawd! Include the shipping costs ($11+ for a small bubble envelope?) and that's over $2 a clip.
            And there's only 10 of them so he's still 6 clips short.
            • dbeardslee
              • 4385
              • Maineville, OH
              Zip ties work real well for fuel line clamps - especially the tygon stuff. Harbor freight sells a little cable tie gun that makes the job even easier for $6.99.
              • mxmikie
                • Aug 2008
                • 482
                • Bouse az
                lawn mower shop/ rc car store
                • Poprock
                  • Apr 2005
                  • 594
                  • Oregon Coast
                  Use 3/16 Tygon and forget about the clamps.
                    A suggestion if you're using zip-ties anyplace you may be putting your hands back into...don't cut off the excess. Cutting these, no matter what you use, always leaves a sharp edge that will carve you up next time if you're not careful... damhik. Instead use a pair of pliers, and getting as close to the catch as possible, twist the tail off. This will leave no sharp edges. If the zip-tie breaks when you do this, you need a better quality tie...
                    And I fully agree with the original post about the new 'packaging'; it really sucks now trying to find some hardware bits, having to buy a bunch of stuff you don't need. You might try an industrial hardware supplier as many of these sell these sorts of parts still as singles.
