pistons
Theodore Roosevelt -
Could someone tell me how having the throttle wide open affects the compresion test reading please?XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
That's easy... to get an accurate compression test, you have to have something to compress; with the throttle closed, the cylinders can't draw in enough air and you'll get a low reading...Fast, Cheap, Reliable... Pick any two
Let me know
This weekend I'm going to pick up some spare engine parts and I'll be able to spare a piston for a while.
Give me the contact information and I will send out a used piston out of an SG.
I think for ring purposes it does not matter.
Correct me if I'm wrong.
Or did this die on the vine?
RickXS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
XS1100SG Project bike
http://s910.photobucket.com/albums/a...t=DSCF3034.jpgComment
Rick
A Vernier or dial caliper is fine.
I have the specs on the rings that should fit but I
am not allowed to release the part numbers until
I can confirm the ring groove depth.
Thanks in Advance,
TECHLINETOMTECHLINETOM
1982 XJ1100Comment
It had never occurred to me before!
What's even more interesting, if you remove the carbs you'll get an even higher reading; somewhere in the neighborhood of 200 psi. The restriction of the closed slides limits the air that gets into the motor too...Fast, Cheap, Reliable... Pick any two
This is what I got
2nd compression ring Groove 3.25 MM
Oil Rail groove 2.62 MMXS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
As per my measurements
O.K. Guys here's the deal.
Can someone measure as accurately as possible the ring groove depths on a new piston?
I have part numbers for the rings (Top, Second and Oil as well as Gapless top and rail) but Ed @ Total Seal made me promise not to release them until I could confirm the ring groove depths.
Once I get the depths (I believe they are not all the same so please measure all three) I can get them put on the computer system @ Summit Racing
and I will post them here as well as the XJ forum so we can get rings.
Piston has 45K miles on it that and I'm not a machinist.
I did the best I could.
RickLast edited by Rickrod3; 01-04-2011, 04:54 PM.XS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
GROOVY ! ( pun intended)
That's exactly what I needed.
Thankyewvurrymuch!!TECHLINETOM
1982 XJ1100Comment
Groove to ring relationship
What is the desired effect of the the groove depth to the cross section of the ring?
I'm guessing it has to be able to secure the ring and allow it to compress as needed but; is there an exact ratio? cross section to groove depth.
Is there an additional way to tell if you way ring wear besides the end gap?
I'm thinking the cross section would be smaller as the ring wears.
I measured a couple rings and they were 2.98 MM and 2.18 both smaller than the groove.
Being that rings are designed to wear this data really is meaningless unless I knew what the original dimensions of a ring would be.
TIA
Rick
PS any new developments with getting ring replacements?Last edited by Rickrod3; 01-09-2011, 03:43 AM.XS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
O.K. here is the word on the rings.
Total Seal doesn't have an oil ring to fit because the ring groove is too shallow.
The second ring they might have off the shelf depending on the measurement.
The top ring is a go.
I tried to get them added @ Summit Racing but the part number system is set up differently @ Total Seal for ring sets in less than lots of 500!
So all of our ring sets are custom except for the Wiseco giant pistons.
Contact Ed Law @ 800-874-2753
PLEASE CONTACT ED LAW ON ALL CUSTOM ORDERS.
Ed told me that they can even machine the ring grooves on your pistons.
Once you get a Quote Number from Ed all you have to do is contact Summit Racing and purchase the Quote Number.
Ed said that you would get a better price thru Summit than from Total Seal direct.
Thanks,TECHLINETOM
1982 XJ1100Comment
top end rebuild
i am doing a rebuild kit on my topend now..wiseco 1179 got mine from dynoman in fl....but he dropshipped from a company in ohio...515 plus shipping....but i got a mechanic doing my work ..bought the bike with 20xxx miles on it and seemed tight but after a month of riding started smoking done a leak down and 1,2 and 4 leaked down 14 and 3 leaked down 40 ....just went ahead and made sure no wear with a bore and new kits they come with pistons rings wrist pins clips and new gasket....i think that was all there didnt open mine just dropped it at the shop.........anyone know how much difference i will see from going from a 1101 to 1179 ????i am just curious..thanks GUMPwindjammer gump
bikes now own
1981xs1100sh special
1971 cb 350
mini chopper project
bikes use to own
1978 750/four..
1983kz1100 ltdComment
