MikesXS coil numbers?
  • Haarstad
    • Sep 2010
    • 95
    • Dexter, MN
    people told me just to go with the green coils as the black ones tend to have problems, where do i get plugs with resistance if i get the non-resistor caps? and are they more expensive?
    Eric Haarstad
    Minnesota
    1979 XS1100 Special
      Any auto parts store should be able to get either type of plugs. I have usually found the non resistor on the shelf but resistor plugs you have to ask for or order.
      • Haarstad
        • Sep 2010
        • 95
        • Dexter, MN
        Then i'm just gonna go with 5k caps, just to make life easier and to avoid anybody from just throwing a non-resistor type in there if a plug were to foul out or something
        Eric Haarstad
        Minnesota
        1979 XS1100 Special
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          I have found it easier to get resistor plugs, as most cars use them in addition to the resistance of the plug wires, but I have also found every auto parts store I have checked with to have the non-resistor plugs as well, and since that's factory, I too stick with the resistor caps and non-resistor plugs.
          Personally I have seen several on here that have been running the black coils for some time, and then some who had problems, but I've seem a few with green coil problems too, so I'm figuring black and keep all my stock parts in case I have to revert.
          • Haarstad
            • Sep 2010
            • 95
            • Dexter, MN
            i haven't heard anything bad about the green coils but i haven't been on the site for too long either so that might be the reason
            Eric Haarstad
            Minnesota
            1979 XS1100 Special
            • cywelchjr
              • 4450
              • Sacramento, CA
              Oh, don't get me wrong, the green coils apparently have a lower failure rate, but since I can fit a set of black coils into my budget, but not a set of green coils, I'll be going with the black ones and take my chances. I understand the black ones are easier to get mounted up too, so for the moment that's gonna be my choice.
              • Haarstad
                • Sep 2010
                • 95
                • Dexter, MN
                ok, i'll just have to see how my budget goes, i have too many things to do and i don't wanna think about how much it'll cost lol
                Eric Haarstad
                Minnesota
                1979 XS1100 Special
