Here's a pic of a couple of FJ fork stems; these are dimensionally the same as an XS stem as far as the bearings are concerned...
[IMG]
[/IMG]
If the 'lip' you're talking about is the one on the 'big end' of the stem, this is where you press the bearing on. It takes a fair amount of force to install this bearing; polite light tapping won't do it. Again, check your bearing number; no matter what 'brand' you have, it will still have the same number as these are industry standardized. I'll note that the lower stem has been modified; this 'bearing area' was built up/remachined to raise the bearing for a swap.
Most any machine shop and many auto repair shops will have a press, so finding someone to press this on shouldn't be an issue...
Cost should be under $10 to have this done.
[IMG]
