steering bearings
  • #16
    Here's a pic of a couple of FJ fork stems; these are dimensionally the same as an XS stem as far as the bearings are concerned...
    [IMG][/IMG]
    If the 'lip' you're talking about is the one on the 'big end' of the stem, this is where you press the bearing on. It takes a fair amount of force to install this bearing; polite light tapping won't do it. Again, check your bearing number; no matter what 'brand' you have, it will still have the same number as these are industry standardized. I'll note that the lower stem has been modified; this 'bearing area' was built up/remachined to raise the bearing for a swap.
    Most any machine shop and many auto repair shops will have a press, so finding someone to press this on shouldn't be an issue...
    Cost should be under $10 to have this done.
    • #17
      well i must be an idiot... it looks like the there was a race that was powdercoated over and remained on the stem... that was the lip i was talking about...
      Chris
      twitter.com/thechrisdemon -- instagram.com/chrisdemon
      2012 HD FXDC -- bone stock... for now...
      1980 XS1100 Special --
      under restoration for brother
      2010 HD XL1200 -- good riddance...
      1981 KZ650 CSR -- Found a good/new Home
      1980 CX500 -- livin' it up in FL
      • #18
        What else can you say but "DOH!" Glad you found the problem.
