Thinking of re-routing the fuel lines...
  • g15usmc
    • Nov 2010
    • 365
    • 29 Palms CA
    N/M thats a breather filter yes?
    Daily Driver - '04 Suzuki Marauder 1600
    Project Bike - '79 XS1100 Special
    Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
    Ride Till You Die!
    "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
    “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
    "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
      The filter is probably a small fuel filter replacement from the look of it. Many people do not bother to put a filter on there. As the guys have stated, that T on the carbs if a vent for the fuel bowl, air has to go out for fuel to come in and all. So, as long you do not plug it off, it will work fine. Some folks put a small screen on a piece of fuel line off the T, or you can simply put some small amount of steel wool in the line, whatever you want, or nothing. The reason for putting something over the line is simply to keep critters from going into it and building nest or dying and having their carcus swell up that plug the line.
