Originally posted by Smash
View Post
Stock air filters
wow, never new you could clean and re-use a paper filter. Didn't realize you were supposed to oil the OEMs either. Guess I need to use the search button!Two weeks vacation does NOT make a life.
His: 2006 Ninja 650R, salvaged, 10k miles
Hers: '82 XJ1100 44.4k miles
Paper filters do not like water. You can blow the filter out and knock the dirt off but they will eventually get plugged and not be useful for air passage. The club soda and oxi-clean was was cleaning a K&N filter and NOT a paper filter. If you use water to clean a paper filter you will get mud from the dirt and it will just clog it up and then your screwed.
You can buy rolls of K&N filter material. Strip off the old paper on the stock used filter that you pulled out and put the K&N material in its place and then clean it and treat it as you would a regular K&N filter, then yes you could use the club soda and oxi clean method to clean the new homemade K&N.
I do repeat though DO NOT TRY TO WASH A PAPER FILTER. All you can do to clean a paper filter is knock the dirt out and blow it out with air.Nathan
Ok, that's how I understood it as well. Didn't realize K&N sold their material seperate. I'll keep the old filter and will look to mod it. Thanks!Two weeks vacation does NOT make a life.
My apologies...I just referred to all of them as "paper" filters. I appreciate the clarification.
Nate
Originally posted by natemoen View PostPaper filters do not like water. You can blow the filter out and knock the dirt off but they will eventually get plugged and not be useful for air passage. The club soda and oxi-clean was was cleaning a K&N filter and NOT a paper filter. If you use water to clean a paper filter you will get mud from the dirt and it will just clog it up and then your screwed.
I do repeat though DO NOT TRY TO WASH A PAPER FILTER. All you can do to clean a paper filter is knock the dirt out and blow it out with air.As you say, blow them out with compressed air from the inside and a shop vack on the outside is OK too, two times and dispose and get new as you can never get out the small stuff and air flow is reduced over time. but JIMHO
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Something new every day...
Originally posted by XS1100_OEM4ME View PostNate A+, you are right , never wash a stock air filter or add oilAs you say, blow them out with compressed air from the inside
Ken Talbot
