Stock air filters
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Stock air filters
    Been hearing stock air filters are hard to find, this link was from anouther member getting a carb kit, do these look liks a good replacement for OEM air boxes?
    http://www.carbkitscapital.com/carb_...a&model=XS1100
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    The stock air filters for the XS are easy. It's the XJ1100 ones that are hard to find. When you can find them, they cost a fortune too.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      Xs
      Where is the best place to get stock XS air filters, just checked all 3 on the site and show "sold out"?
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        If you plan on keeping yout bike, drop the extra $ and get a K+N. More air flow than a stock one, perfect fit, re-useable. A K+N combined with a drilled air box will give you a noticable power increase. Last filter you'll ever buy. JMHO
          +1 on the K&N filter. cost about 35 - 50 bucks depending on where you get it. K&N part number is YA-1400.
          • Smash
            • Aug 2010
            • 257
            • Denver, CO
            '82 XJ1100, just dropped $60 on an OEM air filter and they searched and searched for aftermarket but didn't find anything. I just went ahead and sucked it up cause I want to get the bike on the road, but there has GOT to be another option....
            Two weeks vacation does NOT make a life.
            His: 2006 Ninja 650R, salvaged, 10k miles
            Hers: '82 XJ1100 44.4k miles
              There are people that have used the frame a stock filter and then used aftemarket k&n filter material to make their own. When you need a new filter write up a tech report on how to make a k&n xj filter for all the xj owners.
              • Smash
                • Aug 2010
                • 257
                • Denver, CO
                It looks to me very similar to a dirt bike filter... I'll be saving the old one (it's toast) and try to locate an aftermarket.
                  Many XJ11 owners switch to individual pod air filters because, 1. There is no aftermarket air filter available and, 2. The carbs are a real MF to remove and install with the factory air box.
                  • soccer4m
                    • 694
                    partsnmore.com
                    Try the partsnmore.com website. THe stock filters for the xs are 18.00 and in stock, I just got a couple, not sure on the xj but they do carry lots of other parts. Also, the Yamaha dealers can still get either one but are a bit more expensive. The K and N are good but some threads have listed running lean as a problem with that filter since the airflow is not the same as stock, so some had to go into the carb jetting to correct.........again, try the partsnmore website for air filters..................Mike in S.Diego
                    mike
                    1982 xj1100 maxim
                    1981 venture bagger
                    1999 Kawi Nomad 1500 greenie
                    1959 wife
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      Ok
                      OK, must just be me. I got a bike that I got $4,000.00 in that IS WORTH $2,000.00 ON EBAY? An air filter for an XJ (XJ worth about the same IMHO) cost $60.00 and if cleaned and used it right will last the life of the bike The dollars never make sence on these bikes, that is what makes us and them so Special I have had many hot rod cars, spent thousands for no return and I am damm glad I did. There is no price you can put on the "COOL FACTOR"
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                      • Smash
                        • Aug 2010
                        • 257
                        • Denver, CO
                        Yep, pod filters will definitely be a consideration if she decides to keep the bike. Figure I'll give her 10-12 months riding time before she's got a good idea.
                        We have the carb out now, it wasn't too bad to remove with two sets of hands and the airbox moved back as far as it'll go.
                          Once you get it figured out its not hard (relatively speaking) to get the carbs out, that first time though is always fun!
                          • Smash
                            • Aug 2010
                            • 257
                            • Denver, CO
                            Heck of a lot easier than getting the carbs out of my ST1100!!
                            • Smash
                              • Aug 2010
                              • 257
                              • Denver, CO
                              Hold on..... You can re-use the OEM air filter???
