New Member - Need Manual!
    Originally posted by Smash
    Another quick question... Oddly enough a search didn't find me the answer on this one... What's the best place for a reliable fische and best prices on OEM parts? I'm used to Honda.... Thanks!
    or
    • Smash
      • Aug 2010
      • 257
      • Denver, CO
      Thank you!
      Two weeks vacation does NOT make a life.
      His: 2006 Ninja 650R, salvaged, 10k miles
      Hers: '82 XJ1100 44.4k miles
        • 8753
        • Smash
          • Aug 2010
          • 257
          • Denver, CO
          Thanks guys... On the hunt for carb boots!
            Are the carb boots actually leaking or do they just look cracked? The boots are actually metal that is coated in rubber. They may be fine (for now) and just not look pretty. To check if they are bad just spray some carb cleaner, wd40, propane, starting fluid or something flammable around the area to check for vacuum leaks. Make sure all the clamps are tight. and see if the RPMs increase as you wet things down.
            You can also coat the boots with new rubber just to pretty them up in the mean time. Could save yourself some cash this way...
            • Smash
              • Aug 2010
              • 257
              • Denver, CO
              I love this forum.....
              they are cracked to all get-out.... But I figured they were just rubber!!
              I can't believe they're $50 a pop.... No way we can afford to buy 4 new ones...
              So, gonna have to run with the ones on their I guess. We've got the carb off, so I'll see if I can gauge the condition of the metal.
              • Alan1982XJ
                • Aug 2010
                • 29
                • Olympia, WA
                Psh.. 45k miles and looks better than my bike with only 16k....xj as well
                As for the boots... get some rubber tool handle mold or liquid electricians tape. Will look nice and works. Someone on the forums hinted me to this. As long as they aren't damaged all the way through this is good.. as in better then 100 bucks for a new set.
                1982 XJ1100
                • Smash
                  • Aug 2010
                  • 257
                  • Denver, CO
                  Thanks! We haven't even cleaned it up yet.
                  • Smash
                    • Aug 2010
                    • 257
                    • Denver, CO
                    Search isn't popping anything up... Anybody have a source for part numbers for aftermarket oil filters for the XJ1100? Or do I have to buy OEM?
                      XS and XJ use the same oil filter. K&N part number is KN-146. You can get ahold of TC and you can get one of his adapters and then you can use a spin on style oil filter as well.
                      • Smash
                        • Aug 2010
                        • 257
                        • Denver, CO
                        Spin on adapter would be ideal. Just looked at the member list, no "TC" listed... So who's TC?
                        EDIT: nevermind found it. Google is my friend.
                          Sorry his full user name is TopCatGr58. Just to make sure his adapter is the SOFA (spin on filter adapter) http://www.xs11.com/forum/showthread.php?t=5095 or if you want a oil cooler its the SOFCA (spin on filter and cooler adapter) http://www.xs11.com/forum/showthread.php?p=124995
