rounded the shoulders off a bolt on the w/end,,,,,,,,this is how I fixed it
Rounded off nuts/bolts
never ride faster than your gaurdian angel
can fly
1981 rh 5N5
MIDNIGHTSPECIAL
1188cc
4 into 1 pipes with a transac muffler,
as the motorcycling gods intended everything else stock std
http://s856.photobucket.com/home/steptoexs11
http://steptoexs11.webs.com/
http://www.youtube.com/my_videos?feature=mhum
1982 vf750 sabre -
Sure glad you didn't slip and drive that screwdriver through the flesh between your thumb and first finger.Good thing your shop floor is so clean too!
Ken TalbotComment
one of the POs of my bike welded a socked on the bolt.K. Johnson
-1978 XS750SF - brought back from the dead with carb
triple clean and boots
-1982 XJ1100J - brought back from the dead by
replacing motor after throwing #4 rod
-1985 XJ750XN - shim job, oil change, ride. not bad for
$500 including new rear tire.Comment
I actually had a shop weld on a 19mm nut for me. I was never a fan of that 12mm bolt head.Ken TalbotComment
ouch
you saw that did you??
if you listen after I did it you can hear me say ouch when I squeezed the vice handlenever ride faster than your gaurdian angel
can fly
1981 rh 5N5
MIDNIGHTSPECIAL
1188cc
1982 vf750 sabreComment
Am I the only one that keeps an extra new one of this on hand? Anyway now that I have a SOFA, I don't have that problem anymore...
Of all the fixes, I like the welded on 19mm nut the best. Used to be able to buy them that size aftermarket...
The old gray biker ain't what he used to be.Comment
rounded off nuts/bolts
It's a bit more of a PIA, but I used a dremel to downsize the bolt while it was still on the bike. Just couldn't see ripping it out of there by more primitive means. Slipped an 11mm on it, and it came right off. Then I used a new one for the install.
But that old one is going to get the 19mm Talbot Treatment before the next oil change. That's gotta be the ticket on this procedure.
Nice bike in the background though.Comment
For getting rounded bolts out before the file treatment, try these. http://www.koken-tool.co.jp/en/index.html
Click on the Nut Twister. Best damned tool I've ever used for shagged bolt heads. I dont usually use the bolts again, but I could see that reusing the filter bolt may be nessecary, but I'd probably do the 19mm welding thing.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
I use a torque wrench when installing the bolt. Tighten to 20 #/ft and it will come right off every time. 31 years now, same bolt, no oil leaks. Oh yeah, use a six point socket.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
Several years back, SWMBO purchased for me, on fathers day, a socket set called Metrinch... damn things work wonderful. high quality ratchet...even a little round 'finger' ratchet for doing the small stuff. My only complaint is that there aren't enuf deepwell sockets in the larger size.... rounded off bolts are no longer a headache....
4:1 Jardine w/ headerwrap
Windjammer(wiring issues)
New paint/brakes to come!!
'80G FrankenBike (parts bike)
'80G to fix "BlackSunshine"
Stock Pilots/125 mains
Pod filters; 4:1 Kerker??
SS Brake lines w/ new M/C's
LED Brake Lite
Needs paint....
It is better to be thought a fool than to open ones mouth and remove all doubt....Comment
Yep..they grab the 'flats'. I thought so too about the quality when i opened the box...."oh boy, el cheapo tools".... i was wrong. other than previously mentioned deep wells (i have since found out you can buy them separately through the company....) the only bad thing is the screwdriver attachments...the 'socket' they are molded to is too big (diameter) to do a whole lot. 99% of the time i grab these tools rather than my SnapOn or Craftsman tools. If i need 1/2" drive then i go with the SnapOn or Craftsman, but so far i havent needed that kind of wrenching power on bikes....'81H (my first XS ) "Grey Ghost"
LED Brake Lite
Needs paint....
