When testing the ballast resistor what should I get for ohms?
Ballast Resistor Test
Theodore RooseveltTags: None
not sure of the ohms reading,
but if its playing up the engine will sound like it wants
to start but as soon as u release the starter button
the engine dies.
you can also join the two wires together to bypass the switch.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
1.5 ohms or close to it. I have one sitting here that is 1.6 that I just checked.2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Well it is at about 2.3 or 2.4. So that is too high and out of spec correct?Nathan
Hey Nate,
That does sound high. I guess I would expect it to be an all or nothing failure on those. I am no electrical guru for sure though. Its all magic smoke to me.
If your thinking about new coils, you could upgrade coils and elminate that resistor at the same time I would think. It is all down stream of the TCI, so it should not know the difference.Life is what happens while your planning everything else!
Originally posted by natemoen View PostWell it is at about 2.3 or 2.4. So that is too high and out of spec correct?
'78E original ownerFast, Cheap, Reliable... Pick any two
I did order the Green coils yesterday but I am just trying to find all my gremlins. I am also having some issues with the PO changing some of the wires on the pickups, but that is a different thread!Nathan
If you put in the MikesXS green coils, you eliminate the ballast resistor anyway. Those green coils are 3 ohm coils.Life is what happens while your planning everything else!
yeah I know I was just checking for my own curiosity.Nathan
Where's the balast resistor?
Still learning about my 81 special. Where is the balast resistor located? I just installed Dyna 3.0 ohm coils. I beleive I can eliminate the resistor to get more spark? Where is it?klr650 thumper
'75 carbon fiber naked gold wing
Proud new owner 81 Eleven Special (all time fave!)
Formers: 81 Kawi LTD 1000
'79 CB750F, '98 Kawi Connie
Originally posted by klrconcours View PostStill learning about my 81 special. Where is the balast resistor located? I just installed Dyna 3.0 ohm coils. I beleive I can eliminate the resistor to get more spark? Where is it?2-79 XS1100 SF
