Ballast Resistor Test
    When testing the ballast resistor what should I get for ohms?
  • petejw
    • 2269
    • sydney australia
    not sure of the ohms reading,
    but if its playing up the engine will sound like it wants
    to start but as soon as u release the starter button
    the engine dies.
    you can also join the two wires together to bypass the switch.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      • 3189
      1.5 ohms or close to it. I have one sitting here that is 1.6 that I just checked.
        Well it is at about 2.3 or 2.4. So that is too high and out of spec correct?
          Hey Nate,
          That does sound high. I guess I would expect it to be an all or nothing failure on those. I am no electrical guru for sure though. Its all magic smoke to me.
          If your thinking about new coils, you could upgrade coils and elminate that resistor at the same time I would think. It is all down stream of the TCI, so it should not know the difference.
            Yes. But do make sure your meter is accurate; it's been my experience that many cheaper meters aren't too good at reading lower ohms values.
            '78E original owner
              I did order the Green coils yesterday but I am just trying to find all my gremlins. I am also having some issues with the PO changing some of the wires on the pickups, but that is a different thread!
                If you put in the MikesXS green coils, you eliminate the ballast resistor anyway. Those green coils are 3 ohm coils.
                  yeah I know I was just checking for my own curiosity.
                  • klrconcours
                    • 28
                    • duluth mn
                    Where's the balast resistor?
                    Still learning about my 81 special. Where is the balast resistor located? I just installed Dyna 3.0 ohm coils. I beleive I can eliminate the resistor to get more spark? Where is it?
                    klr650 thumper
                    '75 carbon fiber naked gold wing
                    Proud new owner 81 Eleven Special (all time fave!)
                    Formers: 81 Kawi LTD 1000
                    '79 CB750F, '98 Kawi Connie
                      • 3189
                      The 81 doesn't use the ballast resistor so you might have a hard time finding it
                      • klrconcours
                        • 28
                        • duluth mn
                        easy fix! I can get on to riding!
                        BTW that must be why my large brain could'nt find it!
                        klr650 thumper
