Tank Paint?
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Tank Paint?
    Has anyone found a good black/gold flake paint to match the 79 OEM paint?
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
  • CatatonicBug
    • 6117
    • Clinton, UT
    What kind of paint are you looking at? The 2-part automotive stuff can be mixed to any color, but is rather pricey...
      2 part automotive isnt that expensive. You could get a pint (which would be way more than you need) for about 30-35 dollars.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Paint
        Auto base / coat clear is what I am thinking but looking a paint chips and then what it looks like on the bike when it is too late can be bad, i was hoping someone had found a brand/ auto paint code that worked great as I cant find a jobber that can match it from yamaha year/model?
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          Hi Nate,
          not around here you couldn't. Saskatoon price for a one US pint can of the Pumpkin's Tangier Orange, which is a plain ol' GM fleet colour, is $60 not including the hardener and extender that needs to go with it. And so what if a pint is far more than you need? You still gotta buy the whole pint, eh? BTW, fancy metalflake and pearlised paints can cost up in the hundreds, someone posted here about some wondrous fancy-dan paint that cost him $500 a pint. I wasn't so miffed about my $60 paint after reading that.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Paint
            Thanks, that is what I mean, dont want to spend $500.00 just to find out I need to spend anouther $500.00 to fix it, guess no one has found the right paint?
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • Sgriger534
              • 66
              • Farragut, IA
              I work at a Orielly's and some of our stores have a paint scanner. It is called a spectrometer and it is kind of a cool deal. You just need somthing atleast a foot square for them to take three readings off and they can mix you some paint to match. And if you go base coat / Clear coat the paint will probably run you about $25 for a pint, then activator is like another $15 for a quart of that. Then reducer for another twenty and your set for about $60.
              1978 XS1100
              • TADracer
                • May 2006
                • 1417
                • Kenner, Louisiana USA
                Look here: www.paintwithpearl.com
                Their gold microflake is a bit larger than the stock flake but gives a similar job. Beware, it only takes about 1/4 teaspoon (or less) for a quart cup and it gets everywhere. Most people add it to the clear coat but I like it better when added to the black color coat.
                Mike Giroir
                79 XS-1100 Special
                • XS1100 Newbie
                  • Jun 2009
                  • 1106
                  • Battle Ground, Washington
                  Are you all saying that you spray the clear with the same gun as the base? Doesn't make sense. If you ask, the paint store will tell, that you need a different nozzle, and you should not use the same gun. Ask a auto painter if they would use the same gun. Don't know maybe you all have nice equipment. The paint shop we used, only needed about a foot square to get good readings. Also, you want to clean and polish the area you intend to scan.
                  1980 XS1100LG Midnight
                  1991 Honda CBR1000F Hurricane
                  A cold beer and another one!
                  • Rstyduck
                    • 107
                    Excuse me.
                    Im not a painter but i have done some painting.
                    At the cost of Metalflake i know id put it in the clear. The 1st clear coat, 2nd if not enough the 1st time.
                    Then cover with as many coats as i have clean clear left.
                    If im not mistaken, and i dont think i am, If you put the flake in the paint all youll get is painted flake.
                    Not to sure how youll see black flake in black paint.
                    Just my 2 cents.
                    • lee_dutcher
                      • Apr 2009
                      • 822
                      • mason city iowa
                      i work part time a a local body they suggest to use a differnt gun due to needle side in the gun...but i have sprayed clear and color with the same gun just had to adjust patter and feed clear really well...but i will never spray flake again with the same gun sh!t tends to stay in the air passages even after a 24hr soak in anhidrouse
                      1980 gs1000g "stock"
                      2008 jmstar 150cc Chinese scooter ( wife's bike)
                        Originally posted by XS1100 Newbie
                        Are you all saying that you spray the clear with the same gun as the base? Doesn't make sense. If you ask, the paint store will tell, that you need a different nozzle, and you should not use the same gun. - - -
                        Hi Newbie,
                        to spray to a professional standard, yes, you need a different paint gun for every different application, plus a downdraft paintbooth and a 5 year apprenticeship.
                        I got this $30 paint gun and a home made compressor.
                        My paint looks OK from across the street and that's good enough for me.
                        • dbwill
                          • Nov 2002
                          • 30
                          Eastwood company
                          Check out there website. They have all sorts of colors and advice.
                          Eastwood.com
