Oil Change Disaster
  • thewiz
    • Oct 2006
    • 1115
    • Wilksboro, NC
    I may have missed ...
    this reading the thread but removal of the adapter plate will require a different (shorter) center bolt. Be sure you get the bolt with the dog bowl ... lol. Love that term. If you don't want that longer bolt, PM me
    I have cracked one once by over torquing it as well ...
    80G Mini-bagger
    Past XS11s
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      The oil adapter on my bike has a separate bolt that threads into the bottom of the block to hold the cooler adapter in place. Then the standard length filter bolt threads into that. I will guess that some setups just stack the adapter and filter bowl and use a longer filter bolt. If this is the case, yes, a shorter standard length filter bolt will be needed.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • Incubus
        • 1003
        • Austin TX
        He would know that immediately. If the adapter plate came off with the dog bowl then a longer bolt is needed. If the oil filter cover came off alone then a standard bolt will work.
        XS11F (Incubus, daily rider)
        1969 Yamaha DT1B
        • geobiker
          • Mar 2010
          • 82
          • Pa
          My oil plate has the two bolt set-up; the oil filter cover bolt passes through a bolt (pipe) that is threaded (female) on the inside and (male) outside. The oil filter bolt goes inside that double-threaded pipe and the male threads pass through the oil cooler plate and thread into the crankcase.
          I don't believe that the cracks are casting marks as they are rough and irregular. They don't run in straight lines. I still am of the opinion that someone lifted the bike with a jack on the strainer cover and this resulted in the cracks. I was specifically looking for signs of damage when the bike blew oil all over the place. The cracks are bottom near the right side of the cover. They are very near the right muffler and frame and I probably missed seeing them before.
          A replacement strainer cover and gasket is relatively cheap. I would hate to be going down the road and have the cover finish cracking open and drain the oil on the road while the bike is turning 5000 or 6000 rpms. By the time the oil warning light came on, it might be too late!
          Again, thanks for all the info and advice!
          1979 F
          Mac 4-2 Exhaust
          T-Kat Fork Brace
          Spade Fuse Box Mod
          Stainless Steel Braided Brake Lines
          140.0 Main Jets
          45.0 Pilot Jets
          266 X-2 Needle Jets
            They might just be stress cracks from old age. I've had to replace crankcase covers for that reason, most recently a shifter cover that leaked.
              • 2117
              Do you need the oil pan?I have one in my storage unit brand new just sitting there.....
              • geobiker
                • Mar 2010
                • 82
                • Pa
                Thanks for the offer on the oil pan . . . I already have one on the way.
                1979 F
                Mac 4-2 Exhaust
                T-Kat Fork Brace
                Spade Fuse Box Mod
                140.0 Main Jets
                45.0 Pilot Jets
                266 X-2 Needle Jets
