After fd swap
  • dpotter58
    • Aug 2004
    • 1846
    • Southern Maryland
    Well Cool!
    Glad to hear it!
    +1 to Ivan!
    Yeah,
    The 750 / 850 shaft is shorter, and you use the 11 shaft.
    Hope it all rides out smooth.
    Nope. wasn't right. Sometimes you just know it isn't and you can't live with it. With XS north coming up I wasn't comfortable.
    At this point, my fd swap is a failure. after dicking with it all day Friday, part of yesterday and all day today. I pulled it all back off and I'm going back with the original.
    Not sure what went wrong but its a fail...
    1980 LG
    1981 LH
    • gareth
      • Jul 2007
      • 259
      • New York City
      Sorry to hear that, DuWayne. I was following this thread with some interest because I have a 750FD coming from Mr. Ebay anyday soon. I was curious about the mod because I often find myself shifting for that elusive Overdrive-top-gear when I am scooting around. Basically, though, once I have established that I actually AM in top, ( by running out of boot clicks...), the cruising speed RPM's/sound don't bother me. I do have an engine/ handlebar buzz at around 4500 and I wanted to see if I could shift that zone with a 750FD mod so that I can see what's coming up behind me in the mirrors again.
      Could be that you got a dud drive..
      I do like the off-the-line pull of the standard bike, so fitting this would be a wait-and-see project, and as you have found, easily reversible.
      • dpotter58
        • Aug 2004
        • 1846
        • Southern Maryland
        I'm kind of at phuc it. I was looking for better gas milage. I have the old drive back on and the wheel mounted... amybe i'll giv it another try when don't have a trip coming up. I'm getting less than 30mpg on my other bike right now so I didn't want to take that to Canada. Us special guys already hear enough crap about gas stops...
        1980 LG
        1981 LH
        • XSokieSPECIAL
          • Jun 2009
          • 1631
          • Tulsa, OK
          #34
          I hear that potter! However, I can STILL feel my legs and feet!
          • XJOK2PLAY
            • 2099
            • Skiatook, Ok.
            #35
            dpotter58,
            Wow... sorry to hear it didn't work out...
            Sooo, you went back w/ the stock FD and it bolted right up? Everything lined up right w/ the axle?
            I'm thinkin' somethin's stinkin' w/ the FD you got...
            I just did this myself... and the hardest part of the whole thing for me was getting the shaft inserted back into the u-joint... which wasn't that bad...
            Sorry to hear this has gone badly for you.
            The only thing I see you & I did differently was I didn't mess w/ my swingarm.
            But, what gets me is if your saying that the stocker fell right back into place... there would then HAVE to be a difference between the 2 drives, looks to me like...
            2011 Kaw Concours 14 ABS
            • dpotter58
              • Aug 2004
              • 1846
              • Southern Maryland
              #36
              For the life of me I can’t figure out what was up with that deal. The dimensions are the same on both drives. The axel offset was so bad I knew it wasn’t right but I did try as Ivan suggested and it went in OK. However, when I was putting the caliper on I could see it wasn’t lining up correctly.
              Since I’m planning on riding to Canada, I thought the best thing to do was pull it off and go back to stock. When I did everything went back as it was supposed to.
              The only thing I found when taking it apart was the spring that goes into the shaft wasn’t in place. It was laying there sideways but I don’t think it could have gone together and it must have become dislodges when taking it apart…
              I just don’t see how anything I did could have thrown the alignment so out of whack. I’m going to give it another go at some point though. Just not before a trip out of the country.
              1980 LG
              1981 LH
              • dbeardslee
                • 4385
                • Maineville, OH
                #37
                If you look at the two springs - one from the 750 and one from the stocker - one is longer than the other. Gotta use the longer one with the 750FD. If it fell out, that could be from the drive shaft spacer length.
                • XJOK2PLAY
                  • 2099
                  • Skiatook, Ok.
                  #38
                  You know, I had read several places that there's supposed to be a difference in length of those springs... so when we got to that part, I compared the 11 spring w/ the 850.... NO difference! The 2 were identical.
                  Do you suppose there's a difference between the 750 & 850 spring lengths?
                  Can't imagine why that would be...
                  Besides, by the picture I saw of his FD, it was bolted all the way up to the flange... I didn't see any gap at all. Spring probably dislodged upon disassembly.
                  Just thought I'd throw that little bit out there... FWIW...
                  • dbeardslee
                    • 4385
                    • Maineville, OH
                    #39
                    I checked the fiche, and sure enough the 850's use the same spring as the 11's. 750's are a different part number. I know on mine I used the longer spring, and IIRC it came off the 11 FD.
                    • dpotter58
                      • Aug 2004
                      • 1846
                      • Southern Maryland
                      #40
                      I used the spring from the 11
                      1980 LG
                      1981 LH
                      • XJOK2PLAY
                        • 2099
                        • Skiatook, Ok.
                        #41
                        dpotter58,
                        Since you've got the 750 drive back out, I was just wondering...
                        What's the number on that drive?
                        I wonder if it for sure is an XS750 FD....
                        JAT
                        • dpotter58
                          • Aug 2004
                          • 1846
                          • Southern Maryland
                          #42
                          dpotter58,
                          JAT
                          1J7YO is the only number i see
                          1980 LG
                          1981 LH
                          • XSokieSPECIAL
                            • Jun 2009
                            • 1631
                            • Tulsa, OK
                            #43
                            Item Part # Description Notes Req
                            1J7-46101-N0-00 RR AXL GR CASE ASSEMBLY TYPE II 1
                            The first 3 #s match.
                            • XJOK2PLAY
                              • 2099
                              • Skiatook, Ok.
                              #44
                              Ok. That shows to be from an XS750, allright.
                              Just thought it was worth checking.
