Update
sorry, again, i'm slow. (and sick..)
so i repaired the diaphrams with a very thin coat of RTV.
ALL were done identicly.
floats are set at 25.2mm (25.7 +- 1mm is factory)
Main jets drilled to 1.48mm (137.5, 1.375mm factory)
Needles are in middle slot
colortune results
Idle = good/blue
Mid = ok/blue
High = bad/orange-yellow
i was thinking drill the mains a size bigger 1.54-1.59mm
(whatever i can find for drill bits in that range)
then drop the needle down to lean the mid rpm range since it was very close to right with the 1.48mm jet.(but do i go 1 slot or 2?)
if anyone has any thoughts please let me know if i'm going in the right direction with these modifications.
Thanks all
colortune results
Idle = good/blue
Mid = ok/blue
Thanks all
and i'm growing a distaste for it.
