Engine Guard fit question?
  • Engine Guard fit question?
    Does anyone know if an 80 SG three point engine guard would wit a 78E without modifications? TIA
    As far as I know, it would. The structure of all the frames is identical, as is that of the engines.
      Thanks! thats what I figured but I just wanted to make sure!
        I've a three point on my 78E, fits fine.
        Darrell
        78E
        80G project
        06FJR
          Yes the crash bars will fit.
          I just mounted a set on my 79 xs11 special.
          BUT, the main engine bolt may not be long enough.
          mine was not. so i cut it in the middle and
          tig welded in 3/4" of grade 5, bolt shank.
          Now it's long enough.
          it was 1/2" inch too short, i couldn't thread the nut on over the brackets.
          1981 Yamaha XJ750RH Seca (War Pig) XS11S front end and rear swingarm with 17" rim, 20mm ammo box saddle boxes, HID headlight, LED aux lights, Heated grips & seat, Bark busters, Harley 12" shocks, S.S. brake lines, oil cooler
          PW50, PW80, YZ80(mine? what the??? Brrap OH...)
            +1 on the bolt length. I went to Home Depot and bought a length of all-thread, some SS washers and nylock nuts, and created my own "bolt" for mine. Unfortunately, the way mine fit (not sure if they are all the same), I have to remove the whole right-side guard to get the alternator cover off. The timing cover will come off without removing the guard on the left side though.
