Engine Guard fit question?
    Does anyone know if an 80 SG three point engine guard would wit a 78E without modifications? TIA
    As far as I know, it would. The structure of all the frames is identical, as is that of the engines.
      Thanks! thats what I figured but I just wanted to make sure!
      • newc4
        • 643
        • Vienna VA
        I've a three point on my 78E, fits fine.
        Darrell
        78E
        80G project
        06FJR
        • MindWebs
          • May 2009
          • 431
          • Baldwin, WI
          Yes the crash bars will fit.
          I just mounted a set on my 79 xs11 special.
          BUT, the main engine bolt may not be long enough.
          mine was not. so i cut it in the middle and
          tig welded in 3/4" of grade 5, bolt shank.
          Now it's long enough.
          it was 1/2" inch too short, i couldn't thread the nut on over the brackets.
            +1 on the bolt length. I went to Home Depot and bought a length of all-thread, some SS washers and nylock nuts, and created my own "bolt" for mine. Unfortunately, the way mine fit (not sure if they are all the same), I have to remove the whole right-side guard to get the alternator cover off. The timing cover will come off without removing the guard on the left side though.
