rear master cylinder
  • jeffro1954
    • Aug 2009
    • 72
    • Minnesota
    could someone layout (picture would be awesome) the order of the parts in the rear master cylinder? bought a kit, but don't recall seeing the little washer when I took it apart. does it really go against the part with the little holes and then the seal over the washer? And it seems like the little metal boot next to the spring could go either way. Everything is spotless but no fluid is moving into the line. that little washer (not the one that is cutout) must serve a purpose to create pressure.
    1978 XS1100
    1979 Honda Goldwing
    Can't help you much with your questions, can't remember the last time I had one apart, here's the diagram at least....
      This may be a bit large
      Here's an exploded view from the Yamaha Parts web site found in the links section! You can click on it to view it larger!
      Hey Phil,
      You beat me!!! And nicer picture, too!!!
      • jeffro1954
        • Aug 2009
        • 72
        • Minnesota
        Thanks, I have seen some exploded views like this but they are still not clear on the little washer. the rebuild kits come with them but I'm wondering if it's an "extra" part that is not used. the one photo looks like the part with the hood goes over the spring and not the plunger.
        1978 XS1100
        1979 Honda Goldwing
        • Montreux_Blue
          XS-XJ Guru (Deceased)
          • 1143
          Looks like Phil's picture is a lot clearer!
          Famous Myspace quote:
          • Toolmaker Tim
            • 671
            • South Bend, Indiana
            Little Washer
            The small thin washer goes on top of the top seal. It sets below the cup that holds the bottom of the spring. Just got done working on mine.
            1979XS1100SF
            K&N's and drilled airbox
            Jardine 4in1
            Dunlop Elite 3's
            JBM slide diaphragms
            142.5 main jets
            45 pilot jets
            T.C.'s fusebox & SOFA
            750/850 FD mod.
            XV 920 Needle Mod.
            Venture Cam Chain Tensioner
              Yes it covers up the little holes on the end of the plunger.
              • jeffro1954
                • Aug 2009
                • 72
                • Minnesota
                Thanks a million. I put together the last time as you described but wasn't sure it was right so this saved me from taking it apart one more time.
                1978 XS1100
                1979 Honda Goldwing
