wiring questions
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Did you only check one, or all four? Really ought to check all of them because some problems show up in "pairs" because 2 cylinders share a coil.
    Anyways, next thing I'd check is to see if you have +12v to the coils, you'll have to pull the tank and seat and then put the black probe of your meter to the - battery terminal and the red probe of your meter on the wire that is shared by both coils, I think its red/white.
    If you do then I'd check your connections at the TCI and check the pickup coils. Take a quick read of the other "no start" thread thats going right now, should explain how to check the TCI and the pickups.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
      Well, now the fun begins. I'd start at the fuse box to see what does or does not have power past there. Then check for voltage at the coils, check your coils by disconnecting the wires and see what resistance you get.
      Basically, its electrical trouble shooting time. For me, this is always like chasing a rabbit. Start at one end checking for power and see where it stops.
      • randy
        • Dec 2003
        • 4521
        What about the tip-over switch? Could be installed upside down. Don't ask me how I know that
        • jte8969
          • Jun 2009
          • 44
          • Georgia
          where would the tip over switch be located??
          1981 xs1100SH, my first bike and bike project!
          • randy
            • Dec 2003
            • 4521
            Under the tank, between the frame rails, just rear of the headlight relay. It has embossed wording "UP" on it. Two prong plug.
            • psycoreefer
              • Feb 2008
              • 1557
              • Minden, NV
              also, you can just unplug it, no need to jump the wires.
              My Bike:
              [link is broken]
              • randy
                • Dec 2003
                • 4521
                Sure, but you'll still have to make sure it's not up-side down before you plug it back in!
                  Of course, you could just ride without it. But then, that could prove bad for you in an emergency situation.
                  I found that Thunderstruck took quite the trip without me, down a guardrail. In that case, though, the wheels were stuck against the ledge of blacktop and the bike was leaned against the guardrail and it just went till it ran out of guardrail. No tip switch could stop that one.
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    Yeah, you would need one of those kill switches like on jet skis that have a tether on your wrist that unplugs if you fall off and kills the engine.
                    • psycoreefer
                      • Feb 2008
                      • 1557
                      • Minden, NV
                      or just don't plug it back in
                      The way I see it if the bike tips over, the wheels aren't touching the ground anyways and so what difference does it make if its running - sure it might trash the motor, but the rest of the bike would likely be totaled anyways.
                      My Bike:
                      [link is broken]
                      • randy
                        • Dec 2003
                        • 4521
                        Well, theoretically, killing the motor also kills the vacuum - actuated fuel taps so you don't have fuel dumping out of the carbs onto a hot running engine....then again, that assumes your gas cap gasket is not all cracked and leaky...which on these is hit or mis...oh, never mind!
                          I had an incident about two years ago. Front tire slid out on me, as I came up on a turn trying to slow down. Long story short, I wound up "Parked" laying down in the grass with a sign post behind the bike about four feet, and a utility pole in front about three feet and the guy cable for it just beyond the bike. Sort of my own little parking spot there. Anyway, the bike was dead due to a blown main fuse, but if it had been running, the angle of the hill could have easily let the rear tire get a grip on the ground. then it would be any one's guess as to who or what would have been damaged.
                          Makes that simple little switch seem REALLY easy to turn over and plug back in. JMO
