Who wants a better way to fill your Air Forks?
  • MindWebs
    • May 2009
    • 431
    • Baldwin, WI
    I just set this up on mine and thought i would share.
    Fork Air rail assembly instructions with pictures.
    Who wants an easier way to fill and check fork air pressure?
    Assembly and installation take approx. 1-2 hours.
    Approx. Cost is $25-$40 Depending on material used.
    Parts list:
    2 – 1/8” Pipe Tee’s, can be: brass, black steel, stainless steel, aluminum, (it’s your choice.)
    1 – 1/8” Pipe Nipple (same material as tee’s.)
    2 – 1/8” to 3/16” Hose Barb fittings, again brass, black steel, stainless steel, aluminum.
    2 – Hose Clamps, of the smaller variety, not sure of their measurements.
    1 – 1/8” Tank Valve,
    1 - 1/8” NPT 0-30 PSI Gauge (would be best) or whatever you can get your hands on.
    1 – A bit of thread sealant compound of your choice, Teflon tape or liquid..
    2 – Zip ties, I like black ones.
    #1. Place bike on center stand.
    #2. Remove fork valve caps.
    #3. Remove fork valve cores.
    #4. Take the 9” haltec extensions and cut the inlet ends off (end end that looks like the tire fill valve).
    #5. Thread the extensions onto the fork valve stem, tighten to snug,(rubber seals well)
    #6. Using thread sealant assemble thread your nipple into the tee’s and tighten.
    #7. Using thread sealant assemble thread your hose barb fittings into the tee’s.
    #8. Using thread sealant assemble thread your tank valve into one of the tee’s.
    #9. Using thread sealant assemble thread your air pressure gauge into the other tee.
    #10. Route the hoses to the air rail assembly, carefull not to kink them.
    #11. Slide the hose clamps onto hoses.
    #12. Slide hoses onto barb fittings and tighten clamps.
    #13. Wrap zip ties around air rail assembly and handle bars and tighten to desired snugness.
    #14. Add air to rail, Ride and adjust to comfort level.
    Note: only add air when on side stand.
    Note: Only adjust with you sitting on the bike and off all stands.
    Note: If you use the tire pressure gauge like I did, you will have to cut the brass rod off the gauge.
    I just want air assisted forks
    • Guy_b_g
      • May 2007
      • 790
      • Beverly Hills, Florida
      Here is another alternative...good for air forks or air shocks, and has a connector that won't bleed pressure when attaching or detaching from the valve. I have one just Like it and am very happy with it.
      There are usually several of these on ebay, so this one may not be the lowest price available.
      Guy
      '78E
      • MindWebs
        • May 2009
        • 431
        • Baldwin, WI
        i think this system is a bit better and you never have to worry about pressure.
        you just look at the gauge.
        and the price is close to the same as your tool, but i can fill at any gas station and get a precise adjustment everytime.
          • 2072
          Just a thought-does that throttle cable get in your way of the speedo?Might want to reroute that.
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            Looks annoying... I think its the clutch cable but it doesnt matter.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
              • 2072
              It is the clutch-that would bother me if i couldn't see.
                • 8798
                I had a similar setup years ago on my 79F (80 forks), and it turned out to be a real hassle with all the clutter there. Went to Progressive springs and lost the air altogether. Rode much better. JMHO
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  I'm just curious - What are those triangular blocks clamped to the handlebars on each side??
                  Oh... Nevermind... Those are the windshield clamps.
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    Thanks for the tip and setup
                    I don't know if I will do it, but I appreciate the creativity of the members here that allow for so many options.
                    John
                    '81 XS1100H - "Enterprise"
