Who wants a better way to fill your Air Forks?
  • MindWebs
    • May 2009
    • 431
    • Baldwin, WI
    I just set this up on mine and thought i would share.
    Fork Air rail assembly instructions with pictures.
    Who wants an easier way to fill and check fork air pressure?
    Assembly and installation take approx. 1-2 hours.
    Approx. Cost is $25-$40 Depending on material used.
    Parts list:
    2 – 1/8” Pipe Tee’s, can be: brass, black steel, stainless steel, aluminum, (it’s your choice.)
    1 – 1/8” Pipe Nipple (same material as tee’s.)
    2 – 1/8” to 3/16” Hose Barb fittings, again brass, black steel, stainless steel, aluminum.
    2 – Hose Clamps, of the smaller variety, not sure of their measurements.
    1 – 1/8” Tank Valve,
    1 - 1/8” NPT 0-30 PSI Gauge (would be best) or whatever you can get your hands on.
    1 – A bit of thread sealant compound of your choice, Teflon tape or liquid..
    2 – Zip ties, I like black ones.
    #1. Place bike on center stand.
    #2. Remove fork valve caps.
    #3. Remove fork valve cores.
    #4. Take the 9” haltec extensions and cut the inlet ends off (end end that looks like the tire fill valve).
    #5. Thread the extensions onto the fork valve stem, tighten to snug,(rubber seals well)
    #6. Using thread sealant assemble thread your nipple into the tee’s and tighten.
    #7. Using thread sealant assemble thread your hose barb fittings into the tee’s.
    #8. Using thread sealant assemble thread your tank valve into one of the tee’s.
    #9. Using thread sealant assemble thread your air pressure gauge into the other tee.
    #10. Route the hoses to the air rail assembly, carefull not to kink them.
    #11. Slide the hose clamps onto hoses.
    #12. Slide hoses onto barb fittings and tighten clamps.
    #13. Wrap zip ties around air rail assembly and handle bars and tighten to desired snugness.
    #14. Add air to rail, Ride and adjust to comfort level.
    Note: only add air when on side stand.
    Note: Only adjust with you sitting on the bike and off all stands.
    Note: If you use the tire pressure gauge like I did, you will have to cut the brass rod off the gauge.
    I just want air assisted forks
    • Guy_b_g
      • May 2007
      • 790
      • Beverly Hills, Florida
      Here is another alternative...good for air forks or air shocks, and has a connector that won't bleed pressure when attaching or detaching from the valve. I have one just Like it and am very happy with it.
      http://cgi.ebay.com/ebaymotors/HARLE...#ht_1193wt_960
      There are usually several of these on ebay, so this one may not be the lowest price available.
      Guy
      '78E
      • MindWebs
        • May 2009
        • 431
        • Baldwin, WI
        i think this system is a bit better and you never have to worry about pressure.
        you just look at the gauge.
        and the price is close to the same as your tool, but i can fill at any gas station and get a precise adjustment everytime.
          • 2118
          Just a thought-does that throttle cable get in your way of the speedo?Might want to reroute that.
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            Looks annoying... I think its the clutch cable but it doesnt matter.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
              • 2118
              It is the clutch-that would bother me if i couldn't see.
                • 8962
                I had a similar setup years ago on my 79F (80 forks), and it turned out to be a real hassle with all the clutter there. Went to Progressive springs and lost the air altogether. Rode much better. JMHO
                  I'm just curious - What are those triangular blocks clamped to the handlebars on each side??
                  Oh... Nevermind... Those are the windshield clamps.
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    Thanks for the tip and setup
                    I don't know if I will do it, but I appreciate the creativity of the members here that allow for so many options.
                    John
                    '81 XS1100H - "Enterprise"
