do i need this gear
  • jmcmillan40
    • Apr 2010
    • 68
    do i need this gear
    this is on a xs1100
    and the one in my xj1100 doesnt have this on it?
    and no kick start mech but i have one would you install it?
    Yup.. you NEED that if you want the bike to stay in a gear. A detent pin rides on that on the right side of the motor. As you shift a gear, that detent pin rides into the next notch as that shift cam rotates, and it holds all your gears in the right place. Pretty critical little dude... I have lost that clip on the end of that before and it got cocked sideways on the shaft. It wouldn't shift any more, and it required splitting the cases to fix it. No difference in the transmissions between the XS/XJ besides the early models had that kickstarter gear in there.
    • jmcmillan40
      • Apr 2010
      • 68
      ok well?
      so the little nob on the end of the shift drum is gone and so is that star thing?
      on my xj 1100 and its installed in the bike
      the pictures is from a xs1100 and as you can see this star thing is on there
      • jmcmillan40
        • Apr 2010
        • 68
        ok here is my trans what is missing
        ok 1st here is my tranny and see in the picture no gear and i dont se any thing for that star thing to grab onto ie detent pin? i now the oil pums sits right above it.
        does that star thing along with detend pin ride on fork shaft that and the countershaft with gears is all that i took out and oil pump.
        also see that gear on the main shaft thats the one i cant get main and 1st gear past i need like 1/8 inch to get 1st gear past it.
        • jmcmillan40
          • Apr 2010
          • 68
          also
          i do see it in this pic of the tranny in overview but dont see what it would ingage with
            In the pic of your transmission without that star plate, the detent pin is underneath it shown here...
            You have to split your cases to get to this bolt and detent pin.
            Flipped over, with the plate installed.
            Not going to be much help with the gear install since I normally split the cases to do so. I have heard of people having problems because of that kickstarter gear you have in there.
              The little knob on the end is still there. It's part of the shaft and installed into a hole in the case right under that #22 you see in the pic. What's missing is that star plate and a circlip that holds it on.
              • jmcmillan40
                • Apr 2010
                • 68
                ok so?
                ok i see so in order to remove shift drum so i can put that gear on i hhave to split cases wich means i fliped bike for nothing becuasy i got to reamove motor now?
                and how owuld that gear be gone and the pin i guess some one eather was in hear and forgot it explanes why it wouldnt shift right, or the star gear broke off when the pin came out?
                • jmcmillan40
                  • Apr 2010
                  • 68
                  i see well
                  ok thanks for your help i see that bolt and also i see underneath there is no DETENT PIN IN BOLT. or anything in that bolt i see that the bolt is holow to allow soMthing in it, do you have a PICTURE OF THE DETENT SPING THAT WOULD GO IN THERE I THINK I HAVE IT JUST DONT NO WHAT IT LOOKS LIKE?
                    This is the pin:
                    This is the spring that pushes the pin:
                      Hmmm.. Looks like I wasted my time doing that... lol.
                      • jmcmillan40
                        • Apr 2010
                        • 68
                        ok got it si it slips inside
                        ok i see it goes inside the bolt and the keeper holds it on there
                        and it is positiond under the shift cam the start lokking gear on the end of the shif drum.
                        well that would explan why it rattled going into 1st gear and wouldnt go into any other gears properly
                        i donr grt how all that would be gone along with the kick start gear someone has been in this tranny and dint put it back right thats what i think
                          Yup.. the spring goes inside the bolt and that detent pin. That metal piece has a slot you put over one of the case ribs, then you bend up a side to lock in the bolt.
                          And yeah, like I said, to take that pin out, someone had to have split the cases. Good luck and keep us informed on the progress.
                          • jmcmillan40
                            • Apr 2010
                            • 68
                            thanks
                            ok i will also one more thing i have a manual online and its really dark anyone hear have some good manula links
                              Click the link in my signature. I have 2 XS Service manuals, one XJ manual, and the owners manuals all there for download. The Clymers XS manual is even formatted with searchable text.
